[SOLVED] "Send tweet with timestamp" sketch hangs, shows no activity
thanks for the reply Paul.
  • Sorry, I changed the order of the strcat from GoodAsh03's original code, but forgot to change it back when posting my revision of code. Originally around the other way, but the order only changes to the order of the messages output in the tweet. will play around with some different wording for those messages later.
  • "Udp.parsePacket() returned false."
I really dont know what code to use or move around, been trying different things, but nothing seems to work. Quite new to programming
  • "you need to determine if you can, from where you are in the network, actually reach that time server."
i am trying to understand how I can do this better than what is already in the code, but I dont really understand the method required.
thanks for your help!
