Solved: Sending structure over SoftwareSerial- need help to debug
Hi all,
Please can you help me with the below situation, let me know if you need further details.
I have
master-> Arduino nano
slave-> Nodemcu ESP8266, which is programmed by Arduino IDE
Aim is to send set of float values from Arduino to the ESP.
Issue is- I am unable to extract the data, and i get strange nan values. Also i do not get the last 2 terminators.
I had followed the discussion at below link for my execution.
The code at arduino nano, which simply sends data when i reset it.
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 10 (connect to TX of other device)
 * TX is digital pin 11 (connect to RX of other device)
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created back in the mists of time
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
long randNumber;
SoftwareSerial mySerial(6, 7); // RX, TX
struct mystruct {
  float temperature;
  float rainfall;
  float humidity;
  float wind1;
  float wind2;
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
struct mystruct myData;
myData.temperature = 27.434;
myData.rainfall = 3.9;
myData.humidity = 87.3;
myData.wind1 = 4.98;
myData.wind2 = 5.22;
mySerial.print("\001\002");
mySerial.write((const uint8_t *)&myData,sizeof(struct mystruct));
mySerial.print("\003\004");
Serial.println(sizeof(struct mystruct));
void loop() // run over and over
Output at nano/master
Goodnight moon!
20
The code at the ESP/slave
/*   For Arduino 1.0 and newer, do this:   */
SoftwareSerial mySerial(14, 12, false, 256);
struct myStruct {
  float temperature;
  float rainfall;
  float humidity;
  float wind1;
  float wind2;
char char_in1, char_in2;
char *ptr;
struct myStruct myStructVariable;
long count;
long sizex;
  //start the library, pass in the data details and the name of the serial port.
  Serial.println("started");
  //check and see if a data packet has come in.
  if (mySerial.available()) {
    if (mySerial.read() == '\001') {
      Serial.println("FIRST");
      while (!mySerial.available());
      if (mySerial.read() == '\002') {
        Serial.println("SECOND");
        sizex = sizeof(struct myStruct);
        ptr = (char *)&myStructVariable;
        Serial.println(sizex);
        for (count = 0; count < sizex; count++)
          *(ptr + count) = mySerial.read();
        }  //And I thought the magic should happen here.
        Serial.println("extracted data");
        Serial.println(myStructVariable.wind2);// this is what shows bad data on serial
        //reading terminators
        if (mySerial.read() == '\003') {
          Serial.println("THIRD");
          if (mySerial.read() == '\004') {
            Serial.println("FOURTH");
            Serial.println("message finish");
Output at the slave
‚n?†$“¦£ÿ_SAûstarted
FIRST
SECOND
20
extracted data
nan
where am I going wrong? I am exhausted of trying different permutations :confused:
I think the simplest thing is to use a Union to map the struct to an array of bytes and just send the array using Serial.write().
Have the same data structure on the receiving end.
IIRC that is how I did things in this Python Binary Data demo.
...R
Robin2:
...R
Even simpler would be waiting for data to arrive, before reading it.
Thank you very much Robin and AWOL.
I have checked Robin’s example and I modified my code to do the similar to his waiting for all bytes to come in before reading.
Thanks AWOL, I had achieved that by checking if mySerial.available()=>24; where 24bytes is the length of data I was sending over. This is the only mod I have done to my slave code and it works wonderfully.
Been a great help, changing it to solved now.
