[Solved] Serial Communication Between PC and Arduino using C#
Hello,
I want to Make Serial Communication Between PC and Arduino.
I know how to send data from PC using C# to Arduino but I have few problems when I'm sending Data from Arduino to PC.
Heres My Code:
        String s;
        SerialPort mySerialPort;
        private void Form1_Load(object sender, EventArgs e)
            mySerialPort = new SerialPort("COM4");
            mySerialPort.BaudRate = 9600;
            mySerialPort.Parity = Parity.None;
            mySerialPort.StopBits = StopBits.One;
            mySerialPort.DataBits = 8;
            mySerialPort.Handshake = Handshake.None;
            mySerialPort.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler);
            mySerialPort.Open();
        private void DataReceivedHandler(object sender, SerialDataReceivedEventArgs e)
                s += mySerialPort.ReadExisting().ToString();
                pdata(s);
        delegate void SetTextCallback(string text);
        private void pdata(string data)
            // InvokeRequired required compares the thread ID of the
            // calling thread to the thread ID of the creating thread.
            // If these threads are different, it returns true.
            if (this.label2.InvokeRequired)
                SetTextCallback d = new SetTextCallback(pdata);
                this.Invoke(d, new object[]
                    data
                if (data.Length >= 7)
                    this.label2.Text = "";
                    this.label2.Text = data;
The Problem is that C# dont waits Until it has received full string and it just sends characters to label1 and then clears them.
From Arduino Im sending Test String:
    Serial.println("TEST 1 2 3");
   Serial.println("Arduino");
To Read Text on Arduino I'm Using this Code:
if (Serial.available() > 0)
    int h = Serial.available();
    for (int i=0;i<h;i++)
      inData += (char)Serial.read();
but how to do this on C#?
Have you tried adding a timer to your c# program?
Give it a delay same as the arduino have. It might just work.
Edit:
Read the serialprot at every tick with the C# app.
Thanks.
EDIT: Thanks, I fixed it
How?
PaulS:
How?
i have added timer as Mark5217 said
