[SOLVED] Servo jitter with random angle millis() code
The below code generates a pseudo-random angle every three seconds and then the servo rotates to it. At most angles, large and small, the servo jitters noticeably around its target angle, instead of coming to a standstill. Are there errors in my code that cause this problem?
When I set target angles via serial, no jitter occurs, and also not with other people's random angle servo codes, such as this one. I also made a short 45MB 720p video of the issue.
What am I doing wrong?
#include <Servo.h>
const int timeServoInterval = 7;
const int timeSimUserInterval = 3000;
unsigned long timeNowServo = 0;
unsigned long timeNowUser = 0;
int angleCurrent;
int angleTarget;
Servo ovres;
  //Serial.begin(115200);
  randomSeed(analogRead(0));
  ovres.attach(3);
  ovres.write(0);
  angleCurrent = ovres.read(); // Seed with initial value to start
  angleTarget = random(10, 140); // Seed with initial value to start
  simulateUserInput();
  rotateServo();
void rotateServo()
  if (millis() - timeNowServo >= timeServoInterval)
    timeNowServo = millis();
    if (angleCurrent <= angleTarget)
      angleCurrent ++;
      ovres.write(angleCurrent);
      if (angleCurrent >= angleTarget)
        angleCurrent --;
void simulateUserInput() // Set angle programmatically (later by user input)
  if (millis() - timeNowUser > timeSimUserInterval)
    timeNowUser = millis();
    angleTarget = random(10, 170);
You never seem to recognise that the servo is on target and stop writing to it. You keep adding or subtracting one and writing a new value. Why not a simple "If it's on target do nothing"?
Steve
Thanks, Steve, you were right of course; it jitters because it's looping on, changing "angleCurrent" when the target is already reached before three seconds are over. I added an if statement and now it works as intended. Random angle and two millis() functions running nicely independently.
#include <Servo.h>
const byte timeServoInterval = 6;
int timeSimUserInterval; // Set "do something" interval programmatically
int angleCurrent;
int angleTarget;
Servo ovres;
  ovres.attach(3);
  ovres.write(0);
  angleTarget = random(0, 180); // Seed with initial value to start
  simulateUserInput(); // Values (°) randomly generated within a range
  rotateServo();
void rotateServo()
  if (millis() - timeNowServo >= timeServoInterval) // Check if it is time to rotate
    timeNowServo = millis(); // Record the current time
    if (angleCurrent != angleTarget) // Don't write to servo if target angle is reached
        angleCurrent ++;
          angleCurrent --;
void simulateUserInput() // Set target angle programmatically (later through user input)
    timeSimUserInterval = random(1000, 8000);
