I am attempting to build a circuit that turns a servo motor when a temperature sensor detects that the temp has risen above a certain threshold. I am able to upload code to my board when the servo is unplugged, but when I plug it back in, I am no longer able to upload the code or view the serial monitor in my program.
Here is the error message:
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
[Solved]
I realized that by simply flipping over all of the wiring to the opposite side of the breadboard, the problem was fixed. I have no clue why this made a difference, but it did.
Please post your complete code in code tags </>.
And the complete compiler text using the quote tags (use the speech bubble in the icons in the editor).
Weedpharma
weedpharma:
Weedpharma
Here is my code:
#include <Servo.h>
pinMode(A0, INPUT);
pinMode(13,OUTPUT);
int temp = analogRead(A0);
//convert temp to degrees farenheit
Serial.println(temp);
Servo servo1;
servo1.attach(13);
if(temp > 80)
//tell motor to move 180 degrees and then move back
servo1.write(180);
delay(3000);
servo1.write(0);
delay(3000);
Here is the error message when the servo is plugged in:
Arduino: 1.6.8 Hourly Build 2015/12/23 04:43 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 4,160 bytes (12%) of program storage space. Maximum is 32,256 bytes.
Global variables use 242 bytes (11%) of dynamic memory, leaving 1,806 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": The system cannot find the file specified.
enabled in File > Preferences.
[solved]
see above post
