[SOLVED]Servos write wrong value when using SD card
Hello! I'm trying to control two servos acting as a turret. My program reads values off of an SD card (from an SD card module I built) and then writes the values to the servo. Weirdly, the servos do not write the correct values and freak out. I've written a sister program that doesn't use an SD card and it works fine. Here is the code:
#include <Servo.h>
#include <SD.h>
Servo servoOne;  //x-axis
Servo servoTwo;  //y-axis
const int SDpin = 10; //do not change!
const int laserPin = 4, servoOnePin = 2, servoTwoPin = 3;
int num, servo = 0, spd = 1000;
char array[5];
char posFile[10] = "fOut.txt";
  servoOne.attach(servoOnePin);
  servoTwo.attach(servoTwoPin);
  pinMode(SDpin, OUTPUT);
  pinMode(laserPin, OUTPUT);
  Serial.print("Initializing SD card...");
  if (!SD.begin(SDpin)) {
    Serial.println("Card failed, or not present");
    return;
  Serial.println("card initialized.");
  servoOne.writeMicroseconds(1500);
  servoTwo.writeMicroseconds(1500);
  File dataFile = SD.open(posFile, FILE_READ);
  if (dataFile) {                  //only starts if file exists
    digitalWrite(laserPin, HIGH);
    while (dataFile.available()) { //ends when file is over
      readPosition();
      Serial.println("Number:");
      Serial.println(num);
      if (servo == 0) {
        servo = 1;
        servoOne.writeMicroseconds(num);
      else {
        servo = 0;
        servoTwo.writeMicroseconds(num);
        Serial.println("Got here.");
      Serial.println("Servo one:");
      Serial.println(16.67*servoOne.read());
      Serial.println("Servo two:");
      Serial.println(16.67*servoTwo.read());
      delay(spd);
    digitalWrite(laserPin, LOW);
    dataFile.close();
  else {                          //error if no file
    Serial.println("File not found.");
void readPosition() {
  Serial.println("Array values:");
  for (int i = 0; i < 5; i++) {          //adds the numbers into an array
    array[i] = dataFile.read();
    Serial.println(array[i]);
  char *trunc = strtok(array, "\n\r\t"); //gets rid of extraneous characters
  num = atoi(trunc);                     //converts the string into an int
  if (num == 0) num = 1500;              //resets the servo when the end of file returns 0
The Serial.println()'s are for debugging and give messages like:
Array values:
1
2
7
5
Number:
1275
Servo one:
1166.90
Servo two:
1533.64
Array values:
1
3
0
0
Number:
1300
Got here.
Servo one:
-666.80
Servo two:
1216.91
Array values:
1
2
7
5
Number:
1275
Servo one:
1166.90
Servo two:
1216.91
Array values:
1
3
0
4
Number:
1304
Got here.
Servo one:
-666.80
Servo two:
1216.91
As you can see, the servoOne position is negative, even though the number input makes sense. The positions of the servos do not match the input positions. Also, servoOne goes bonkers when servoTwo is supposed to move!
My thinking is, after much debugging and failing to spot the problem: the SD interface is messing with the servo pins in a way I don't understand. Any other suggestions? Thank you very much!
EDIT: Hello fellow searchers! I found the problem. The char array was too small. I wanted to read in 5 values but I set the array to only be size 5! Char arrays need to have an extra character at the end: \0. That's to show the end of the array. If you overwrite that or one of the characters is erased, then bad things happen. So make your array sizes larger than you think!
Which pins are you using for each servo and the SDcard? Could there be a clash?
For the SD card I'm using 10-13 (10 is the only officially tied pin), and the servos are 2 and 3.
How about printing out the number from the SD card file before multiplying? Are you sure the the negative number is not because of overflow in the multiplication?
Make sure you are reading the data correctly or getting the correct data first.
kf2qd:
That's a good idea, I'll have to look into overflow for one of the functions (strtok or atoi). For my program, the multiplication is for debugging only. servo.read() returns an angle and I want to read it as microseconds, so I multiply by 16.67.
Here's the first few commands, nothing really special about them and certainly not near the overflow for int.
1275
1300
1275
1304
1276
Found the problem! And (re)learned about char arrays! The problem was that the char array where I was storing my values wasn't large enough. I read in five values, \n (line break), followed by a four digit position. The char array was only size five, but char arrays always need to be one larger than you think because the last character has to be \0. So the last digit I read in was getting thrown away. I changed the array size to 6, and it worked!
Thanks all for the help, and always make your char arrays larger than you think!
