[solved] SIM900 Module Cannot Receive SMS
Hey,
I want to receive a SMS send by a second phone to my Arduino Mega2560.
Using the following sketch I’m able to do phone-calls or send SMS’, but when I want to Receive a SMS
there is only shown the message in console: “Received SMS from (sim position: 1)”.
So neither the number of the sender, nor the text I send is shown, while the sketch tells me, that this should happen:
/* GSM Shield example
 created 2011
 by Boris Landoni
 This example code is in the public domain.
 http://www.open-electronics.org
 http://www.futurashop.it
#include <SoftwareSerial.h>
#include <GSM_Shield.h>
char number[]="+39123456789";  //Destination number
char text[]="hello world";  //SMS to send
byte type_sms=SMS_UNREAD;      //Type of SMS
byte del_sms=0;                //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0;    //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
  Serial.println("system startup");
  gsm.TurnOn(9600);          //module power on
  gsm.InitParam(PARAM_SET_1);//configure the module
  gsm.Echo(0);               //enable AT echo
  char inSerial[5];
  int i=0;
  delay(2000);
    Check_Call(); //Check if there is an incoming call
    Check_SMS();  //Check if there is SMS
    //Check data serial com
    if (Serial.available() > 0)
       while (Serial.available() > 0) {
         inSerial[i]=(Serial.read()); //read data
         i++;
       inSerial[i]='\0';
      Check_Protocol(inSerial);
void Check_Protocol(String inStr)
       Serial.print("Command: ");
       Serial.println(inStr);
  Serial.println("Check_Protocol");
    switch (inStr[0])
       case 'a' :  //Answer
           if (gsm.CallStatus()==CALL_INCOM_VOICE){
             gsm.PickUp();
             Serial.println("Answer");
             Serial.println("No incoming call");
       case 'c': // C  //Call
         if (inStr.length()<2)  //To call variable 'number'    comand   c
           Serial.print("Calling ");
           Serial.println(number);
           gsm.Call(number);
         if (inStr.length()==2)  //To call number in phone book position   comand   cx where x is the SIM position
             error=gsm.GetPhoneNumber(inStr[1],number);
             if (error!=0)
               gsm.Call(number);
               Serial.print("No number in pos ");
               Serial.println(inStr[1]);
       case 'h': //H //HangUp if there is an incoming call
         if (gsm.CallStatus()!=CALL_NONE)
           Serial.println("Hang");
           gsm.HangUp();
       case 's': //S //Send SMS
         Serial.print("Send SMS to ");
         error=gsm.SendSMS(number,text);
         if (error==0)  //Check status
             Serial.println("SMS ERROR \n");
             Serial.println("SMS OK \n");
       case 'p':  //Read-Write Phone Book
         if (inStr.length()==3)
           switch (inStr[1])
             case 'd':  //Delete number in specified position  pd2
               error=gsm.DelPhoneNumber(inStr[2]);
               if (error!=0)
                 Serial.print("Phone number position ");
                 Serial.print(inStr[2]);
                 Serial.println(" deleted");
             case 'g':  //Read from Phone Book position      pg2
               error=gsm.GetPhoneNumber(inStr[2],number);
               if (error!=0)  //Find number in specified position
                 Serial.print("Phone Book position ");
                 Serial.print(": ");
               else  //Not find number in specified position
                 Serial.print("No Phone number in position ");
                 Serial.println(inStr[2]);
             case 'w':  //Write from Phone Book Position    pw2
               error=gsm.WritePhoneNumber(inStr[2],number);
               if (error!=0)
                 Serial.print("Number ");
                 Serial.print(number);
                 Serial.print(" writed in Phone Book position ");
               else Serial.println("Writing error");
    delay(1500);
    return;
 void Check_Call()  //Check status call if this is available
     call=gsm.CallStatus();
     switch (call)
       case CALL_NONE:
         Serial.println("no call");
       case CALL_INCOM_VOICE:
         gsm.CallStatusWithAuth(number_incoming,0,0);
         Serial.print("incoming voice call from ");
         Serial.println(number_incoming);
       case CALL_ACTIVE_VOICE:
         Serial.println("active voice call");
       case CALL_NO_RESPONSE:
         Serial.println("no response");
     return;
 void Check_SMS()  //Check if there is an sms 'type_sms'
     char pos_sms_rx;  //Received SMS position
     pos_sms_rx=gsm.IsSMSPresent(type_sms);
     if (pos_sms_rx!=0)
       //Read text/number/position of sms
       gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
       Serial.print("Received SMS from ");
       Serial.print(number_incoming);
       Serial.print("(sim position: ");
       Serial.print(word(pos_sms_rx));
       Serial.println(")");
       Serial.println(sms_rx);
       if (del_sms==1)  //If 'del_sms' is 1, i delete sms
         error=gsm.DeleteSMS(pos_sms_rx);
         if (error==1)Serial.println("SMS deleted");
         else Serial.println("SMS not deleted");
     return;
Could you help me?
     if (pos_sms_rx!=0)
The documentation I found indicates that a negative return value indicates an error:
-1 – comm. line to the GSM module is not free
-2 – GSM module didn’t answer in timeout
You might want to check for those or at least not treat them as good results by changing that last line to:
     if (pos_sms_rx > 0)
Doesn't work.
Maybe there is an error with the return of the char arrays "number_incoming" and "sms_rx"
because they seem to be empty.
If I plug in the SIM in a normal phone, i can read the SMS' send before while the SIM was in my Arduino-module.
Also if I call my arduino the number of my 2nd phone is shown up correctly.
Any other ideas?
Good news.
I just made it run with the example sketch:
 SMS receiver
 This sketch, for the Arduino GSM shield, waits for a SMS message
 and displays it through the Serial port.
 Circuit:
 * GSM shield attached to and Arduino
 * SIM card that can receive SMS messages
 created 25 Feb 2012
 by Javier Zorzano / TD
 This example is in the public domain.
 http://arduino.cc/en/Tutorial/GSMExamplesReceiveSMS
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
  char c;
  // If there are any SMSs available()
  if (sms.available())
    Serial.println("Message received from:");
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    Serial.println(senderNumber);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if(sms.peek()=='#')
      Serial.println("Discarded SMS");
      sms.flush();
    // Read message bytes and print them
    while(c=sms.read())
      Serial.print(c);
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
Thanks for trying to help. :wink:
hey Nathax...can you give the library of the module SIM900 above?
Hi guys, Im new to GSM module. and actually I have a same problem with him.
Hey nat, can you tell me which GSM sim900 module that you use?
Hope you can share this
