[SOLVED] Simple fade program won't work... Why?
Hi
Just trying my new Arduino Uno, I thought writing a fade program for a led was a good idea to test it... So I wrote this in two minutes:
int pin = 11;
  pinMode(pin, OUTPUT);
  int i = 0;
  while (i < 255) {
    digitalWrite(pin, i);
    i++;
    delay(10);
    Serial.println(i);
  while (i > 0) {
    i--;
    delay(10);
I know it's not well optimized but... that's not the point now. And it won't work. The LED stays HIGH everytime, and then shuts down ten milliseconds (I guess) and is HIGH until it's down ten milliseconds, no fade effect, only HIGH a long time and LOW a very very short time. So I tried the example Fade program :
 Fade
 This example shows how to fade an LED on pin 9
 using the analogWrite() function.
 This example code is in the public domain.
int led = 11;           // the pin that the LED is attached to
int brightness = 0;    // how bright the LED is
int fadeAmount = 1;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup()  {
  // declare pin 9 to be an output:
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop()  {
  // set the brightness of pin 9:
  analogWrite(led, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 255) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(5);
And it works... So can anyone say me what is wrong in my program (just to know :p)
Thank you in advance
Sure. The working program uses analogWrite(). The "non-working" one uses digitalWrite(). The digitalWrite() function turns the pin on or off. The analogWrite(0 function varies the duty cycle of the pin.
analogWrite() not digitalWrite()!.
Mark
Oh thanks men.
I feel stupid but... I understood and I won't do the same error now :stuck_out_tongue:
Thanks again
