Hi
I have a problem that an if statement is executed even if the statement is not true. Bellow is the part of code that is concerned.
void VB_Program(){
Serial.print("Option :");
Serial.print(Option);
Serial.print(", Servo No :");
Serial.print(ServoNo);
Serial.print(", Option Val :");
Serial.print(Option_Val);
Serial.print(", Write :");
Serial.print(Write);
Serial.print(", High/Low :");
Serial.print(High_Low_End_Point);
Serial.print(", Option 2 :");
Serial.println(Option2);
//Serial.println("VB");
DetachAllServos(); //Detach all servos to allow Callibration servo to be attaced where needed
ParseSerialString(); //Read and parse serial string into Option, ServoNo, OptionValue, Write, High_Low_End_Point, Option2
Set_VB_Cal_Vals(); //Set values used in callibrating with the VB program
//ValC = EEPROM.read(ValE); //Read EEPROM for current callibration area
if(First_Run == true){ //Only allow this set of steps to happen once at start
if(Option == 1 || Option == 2 || Option == 3 || Option == 5 || Option == 6){
Serial.println(ValC); //Send ValC - Current EEPROM value to VB program
else if(Option == 4 ||Option == 7 || Option == 8){
Val_a = EEPROM.read(ValE_A); //8 bit hvalue
Val_b = EEPROM.read(ValE_B); //8 bit lvalue
ValC = word(Val_a, Val_b); //Set 16 bit value from 2 8 bit values
CallibrationServo.detach(); //Detach old Callibration Servo
CallibrationServo.attach(Call_Servo); //Attach to new callibration Servo
if(Option == 1 || Option == 2){ //End Limits selected
CallibrationServo.write(ValC); //Move servo to current position set in EEPROM
First_Run = false; //Prevent from happening again
//Enables, Servo/Air, Reversing
if(Option == 3 || Option == 5 || Option == 6){
TrimVal = Option_Val; //Set new TrimsVal from VB program
//Same value as in EEPROM
// Foward Reverse
if((Option_Val == 0 && ValC == 0) || (Option_Val == 1 && ValC == 1)){
Value_Send = "Already " + Value_Send; //Set string to send to VB program
Serial.println(Value_Send); //Send string already ..... to VB program
//Differant Value from EEPROM
else if((Option_Val == 0 and ValC == 1) || (Option_Val == 1 and ValC == 0)){
Value_Send1 = "Now " + Value_Send;
Value_Send = "Change to " + Value_Send; //Set string to send to VB program
Serial.println(Value_Send); //Send string Change to ..... to VB program
//**********Problem here*************************************
//Save button pressed in VB program
if(Write == 1){
EEPROM.write(ValE, TrimVal); //Write new value to EEPROM
ValC = EEPROM.read(ValE); //Read EEPROM again
if((ValC == 1 && Option_Val == 1) || (ValC == 0 && Option_Val == 0)){ //Check to see new value was writen to EEPROM sucesfully
Serial.println(Value_Send1); //Send confirmation of value changed
Write = 0; //reset Write (may need to be a timer.)
else Serial.println ("Error writing new value");
//End Limits
else if(Option == 1 || Option == 2){
CallibrationServo.write(TrimVal); //Move servo to current position set in VB program
Serial.println(TrimVal); //Send value back to vb program
if(Write == 1){
if(ValC == Option_Val) Serial.println(Value); //Send confirmation of value changed
//Speed type Cals
else if(Option == 4 || Option == 7 || Option == 8){
Speed_Val = Option_Val; //Set new Speed type value from VB program
Serial.println(Speed_Val); //Send new value back to vb program
if(Write == 1){
Val1_a = highByte(Speed_Val); //8-bit hvalue
Val1_b = lowByte(Speed_Val); //8-bit lvalue
EEPROM.write(ValE_A, Val1_a); //Write new value to EEPROM
EEPROM.write(ValE_B, Val1_b); //Write new value to EEPROM
ValC_a = EEPROM.read(ValE_A); //Read EEPROM again
ValC_b = EEPROM.read(ValE_B); //Read EEPROM again
ValC = word(ValC_a, ValC_b); //Set ValC from 2 EEPROM locations
if(ValC == Option_Val) Serial.println(Val); //Send confirmation of value changed
The problem lies in the line “if(Write == 1){”
if I enter <3,2,0,0,0,0> (Option = 3, ServoNo = 2, Option_Val = 0, Write = 0) in the serial monitor everything works as wanted and " if(Write == 1){" is not executed however if I enter <3,2,1,0,0,0> (Option = 3, ServoNo = 2, Option_Val = 1, Write = 0) “if(Write == 1){” is executed as “Serial.println(Value_Send1);” is executed and printed over the serial monitor even though Write = 0 (Write is the 4th number in the string of 6 entered) as can be seen in the following code which is used to parse the serial commands. I have also confirmed that Write = 0 with the serial.prints at the top of the code shown. How is it possible that this statement is executed???
//Read Serial String
// With help from http://jhaskellsblog.blogspot.com.au/2011/05/serial-comm-fundamentals-on-arduino.html#comment-form
boolean getSerialString(){
static byte dataBufferIndex = 0;
while(Serial.available()>0){
char incomingbyte = Serial.read();
if(storeString){
//Let's check our index here, and abort if we're outside our buffer size
//We use our define here so our buffer size can be easily modified
if(dataBufferIndex==DATABUFFERSIZE){
//Oops, our index is pointing to an array element outside our buffer.
if(incomingbyte==endChar){
dataBuffer[dataBufferIndex] = 0; //null terminate the C string
//Our data string is complete. return true
return true;
else{
dataBuffer[dataBufferIndex++] = incomingbyte;
if(incomingbyte==startChar){
dataBufferIndex = 0; //Initialize our dataBufferIndex variable
storeString = true;
else{
}//End of while loop
//We've read in all the available Serial data, and don't have a valid string yet, so return false
return false;
}//End of boolean getSerialString
//Parse Serial String
void ParseSerialString(){
if(getSerialString()){ //getSerialString == true. String available for parsing
valPosition = strtok (dataBuffer, delimiters);
for(int i = 0; i < 6; i++){
Serial_Data[i] = atoi(valPosition);
valPosition = strtok(NULL, delimiters);
Option = Serial_Data[0];
ServoNo = Serial_Data[1];
Option_Val = Serial_Data[2];
Write = Serial_Data[3];
High_Low_End_Point = Serial_Data[4];
Option2 = Serial_Data[5];
}//End of void SerialString
Any help or ideas???
