I have a simple question about loop. see codes. when SC=10, then SC-1=9, then stLED[9]=0 should go LOW. but it's not the case here. I have to write this line "stLED[9]=0;" to get stLED[9] low. what is the problem here?
If you ever set SC to zero then SC-1 is not a valid array index. Even if you don't see any symptoms yet, it's likely that this is corrupting memory and not working as you think.
PeterH:
will this corrupting memory damage my naon board in long term?
CrossRoads:
No, it just screws up what is stored in SRAM so your sketch does funny things; some other variable is getting its stored value bushwhacked.
I see, so it is something I need to fix. even it has not giving me an error yet.
