Hi everyone
I need to use a rotary encoder as human interface on one of my projects. Considering the libraries I found, it turned out to be simpler to write my own code.
So as a test system, I made something to just change a value between 0 and 255 with increments of 5 and output the value both on LCD screen and on a PWM output (to control the speed of a pump in a heating system)
My sketch is the following :
#include <Wire.h>
int pin_sw = 10;
int pin_a = 11;
int pin_b = 12;
int pin_out = 6;
int state = 0;
int state_sub = 0;
volatile int counter = 0;
volatile boolean flag = false;
volatile boolean flagbtn = false;
int valeur = 0;
LiquidCrystal_I2C lcd(0x20,20,4);
void encoder_read(void)
uint8_t pin_states = PINB & PCMSK0;
// Push button press.
if ((pin_states&0x04)==0)
flagbtn += 1;
pin_states = (pin_states>>3)&0x03;
// state is now 0, 1, 2 or 3.
if (pin_states!=state)
// Exor the old & new states to determine the rotation direction.
int inc = ((pin_states>>1)^state)&0x01;
if (inc==0) inc = -1;
state = pin_states;
// Reset on change of direction.
if ((inc<0 && state_sub>0) || (inc>0 && state_sub<0)) state_sub = 0;
state_sub += inc;
if (state_sub<=-4 || state_sub>=4)
state_sub -= (inc<<2);
counter += inc;
flag = true;
ISR(TIMER2_COMPA_vect)
bitClear(TIMSK2,OCIE2A); // Disable timer2 interrupts.
encoder_read();
bitSet(PCIFR,PCIF0); // Clear pending interrupts.
bitSet(PCICR,PCIE0); // Enable PCINT0-7.
ISR(PCINT0_vect)
bitClear(PCICR,PCIE0); // Disable PCINT0-7.
bitSet(TCCR2A,WGM21); // CTC mode.
bitSet(TCCR2B,CS20);
bitSet(TCCR2B,CS22); // Clk div by 128.
OCR2A = 250; // 2 ms.
TCNT2 = 0; // Clear counter.
bitSet(TIFR2,OCF2A);
bitSet(TIMSK2,OCIE2A);
void setup(void)
lcd.init();
lcd.backlight();
lcd.print("Essai codeur");
pinMode(pin_sw,INPUT_PULLUP);
pinMode(pin_a,INPUT_PULLUP);
pinMode(pin_b,INPUT_PULLUP);
state = 0;
state_sub = 0;
counter = 0;
flag = false;
PCMSK0 = 0x1c;
lcd.clear();
lcd.print("Valeur : ");
if (flagbtn & 1)
lcd.blink();
if (counter)
valeur += counter*5;
counter = 0;
if (valeur>255) valeur=255;
if (valeur<0) valeur=0;
lcd.setCursor(9,0);
lcd.print(" ");
lcd.setCursor(9,0);
lcd.print(valeur);
counter = 0;
lcd.noBlink();
analogWrite(pin_out,valeur);
I first used Arduino 1.0.5 to write that thing, and it worked pretty well. If I turn the encoder only, it does nothing. When I press the encoder button, a blinking cirsor is shown on the LCD and I can change the value wen turnig the encoder, then if I press again the button the cursor disapear and turning no more change the value.
That is the intended behaviour. It is a first test for parameter change for a heating system controller I'm making.
Then I upgraded My arduino IDE, and nightmare started... I first installed the current version, 1.8.2 but then LiquidCrystal_I2C I'm using no more works, and displays only the first character of things I want to display.
Doing some tests I found 1.6.0 to be the last version wich produce something working with LiquidCrystal_I2C. But using this version, my encoder code is not working.
With this version I can press the button the first time to edit the value, then I can edit the value... but I can't go back. Further press on the button are ignored, but rotating is still counting so interrups looks like to work.
Can someone explain me why my interrupt code is working with some version and not with another one ?
Thanks
