Hello everyone,
I'm trying to make a skinner box variant for cats. The goal is for them to push a button and then food is delivered.
There are several schemes according to which I want them to press the button before they get food.
One of them is a random scheme. So a random number is set, the cat has to press the button that many times, it gets food and then the whole loop starts again with a different random number.
I have tried to configure that with the randomSeed() function.. but I don't know how to get a single random number per loop. It just keeps on spewing out random numbers.
So basically, what I want to know, is how to make the random() function just give me one random number.
Thank you
This is the code, I've highlighted the problem part
This code requires a random amount of button presses before activating a servo sweep*/
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be createdint pos = 0; // variable to store the servo position
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int currentTrial = 0;
int lastTrial = 0;
boolean currentButton = LOW; // current state of the button
boolean lastButton = LOW; // previous state of the button
boolean ledState = LOW; // initial led state
long randNumber; // random numbervoid setup() {
pinMode(buttonPin, INPUT); // initialize the button pin as a input:
pinMode(ledPin, OUTPUT); // initialize the LED as an output:
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(0); // brings servo to begin position
Serial.begin(9600); // initialize serial communication:
digitalWrite(ledState, LOW); // turn led of at beginning
randomSeed(analogRead(0)); //random input from analog noise}
boolean debounce(boolean last)
boolean current = digitalRead(buttonPin);
if (last != current)
delay(5);
return current;}
currentTrial = lastTrial + 1;
if (currentTrial != lastTrial)
Serial.print("Trial: ");
Serial.println(currentTrial);
Serial.end();
}do
{currentButton = debounce(lastButton);
if (currentButton != lastButton) // compare the buttonState to its previous state
if (currentButton == HIGH) // if the state has changed, increment the counter
buttonPushCounter++; // if the current state is HIGH then the button went from off to on:
Serial.print("Number of button pushes: ");
Serial.println(buttonPushCounter);
lastButton = currentButton; // save the current state as the last state, for next time through the loopif (currentButton == HIGH){
digitalWrite(ledPin, HIGH);}
else {
digitalWrite(ledPin, LOW);{
randNumber = random(1, 20);
delay(150);
Serial.println(randNumber);
if (buttonPushCounter == randNumber) {
Serial.println("food delivery");
Serial.println(" ");
delay(100);
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(4); // waits 4ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
delay(6); // waits 6ms for the servo to reach the position
delay(50);
while(currentTrial != lastTrial);
