Im pretty sure the problem is in the 'if and' statement at the bottom, but you guys know more than i do.
Error Message:
Arduino: 1.7.4 (Windows 8.1), Board: "Arduino Uno"
Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10704 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src C:\Users\Mike\AppData\Local\Temp\build8927468512460420153.tmp\Sound_Keyboard.cpp -o C:\Users\Mike\AppData\Local\Temp\build8927468512460420153.tmp\Sound_Keyboard.cpp.o
Sound_Keyboard.ino: In function 'void loop()':
Sound_Keyboard.ino:172:28: error: expected primary-expression before '==' token
Sound_Keyboard.ino:172:199: error: expected ';' before ')' token
Error compiling.
/* Code by Mike4449, may or may have not been done before,I made this from scratch. It has 6 buttons, each with a different frequency, and when you push a button, the red LED will turn off and the green will turn on, then the peizo will make the
said frequency until the button is un pressed, while it is doing this, a 1602 LCD will display SOUND BOARD V1.1 and below that will be the frequency that the peizo is making.It is one of the bulkier projects that ive made. Enjoy! 6,648 BYTES, 292 BYTES DYNAMIC*/
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int button1 = A0;
int button2 = A1;
int button3 = A2;
int button4 = A3;
int button5 = 6;
int button6 = 8;
int buzzer = 7;
int led = 9; //green LED
int led2 = 10; //red LED
int setupDelay = 500;
int loopDelay = 2000;
lcd.begin(16, 2);
lcd.print("SOUND BOARD V1.1");
lcd.setCursor(0, 1);
lcd.print("Made by Mike P.!");
delay(5000);
lcd.clear();
delay(2000);
lcd.print("Starting Up...");
delay(2750);
lcd.clear();
lcd.print("Please Wait.");
delay(setupDelay);
lcd.clear();
lcd.print("Please Wait..");
delay(setupDelay);
lcd.clear();
lcd.print("Please Wait...");
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(setupDelay);
lcd.clear();
delay(2000);
lcd.clear();
lcd.print("SETTING UP I/O..");
delay(3000);
pinMode(button1,INPUT);
pinMode(button2,INPUT);
pinMode(button3,INPUT);
pinMode(button4,INPUT);
pinMode(button5,INPUT);
pinMode(button6,INPUT);
pinMode(buzzer,OUTPUT);
pinMode(led,OUTPUT);
pinMode(led2,OUTPUT);
delay(2500);
lcd.clear();
lcd.print("Ready!");
tone(buzzer,440);
noTone(buzzer);
if (digitalRead(button1) == HIGH) {
lcd.clear();
digitalWrite(led2,LOW);
digitalWrite(led,HIGH);
tone(buzzer,440);
lcd.clear();
lcd.print("440 Hz");
if (digitalRead(button2) == HIGH) {
lcd.clear();
tone(buzzer,400);
lcd.print("400 Hz");
if (digitalRead(button3) == HIGH) {
lcd.clear();
tone(buzzer,360);
lcd.print("360 Hz");
if (digitalRead(button4) == HIGH) {
lcd.clear();
tone(buzzer,320);
lcd.print("320 Hz");
if (digitalRead(button5) == HIGH) {
lcd.clear();
tone(buzzer,280);
lcd.print("280 Hz");
if (digitalRead(button6) == HIGH) {
lcd.clear();
tone(buzzer,230);
lcd.print("230 Hz");
if(digitalRead(button1) == LOW && (digitalRead(button2) == LOW && (digitalRead(button3) == LOW && (digitalRead(button4) == LOW && (digitalRead(button5) == LOW && (digitalRead(button6) == LOW) {
lcd.clear();
digitalWrite(led2,HIGH);
digitalWrite(led,LOW);
noTone(buzzer);
lcd.clear();
lcd.print("SOUND IS OFF");
