[Solved] Start problem with the 8*8 LED dot matrix
This is the problem:
Dot matrix start problem
Here is my code:
void SPI_Init(void);
void SPI_TX(uint8_t data);
void MAX7219_init(void);
void draw(void);
void clr(void);
  SPI_Init();
  MAX7219_init();
clr();
_delay_ms(100);
draw();
void SPI_Init(void)
  DDRB |= (1<<DDB3)|(1<<DDB5)|(1<<DDB2); // DDB3 MOSI, DDB5 SCK, DDB2 SS
  SPCR = (1<<SPE)|(1<<MSTR);  // SPI enable, Master Mode
  SPDR = data;
  while(!(SPSR & (1<<SPIF)));
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0C); // shutdown
  SPI_TX(1);
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0A); // intensity
  SPI_TX(1);
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x09); // decode mode
  SPI_TX(0x00);
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0B); // scan limit
  SPI_TX(0x07);
  PORTB |= (1<<PB2);
void draw(void)
  uint8_t descend[9]={9,8,7,6,5,4,3,2,1};
  uint8_t ascend[9]={0,1,2,3,4,5,6,7,8};
  uint8_t data_mask[5]={3,5,7,9,0x0A};
  uint8_t i,k,p,device=0,offset;
  uint8_t row=4,col=5;  // suppose are func args
  for (i=0;i<9;i++)
    for (k=1;k<9;k++)
      PORTB &= ~(1<<PB2);
      SPI_TX(k);
      /*if ((k % 2)==0)
        SPI_TX(0);
      SPI_TX(data_mask[0]);
        for (p=0;p<device;p++)
          SPI_TX(0x00);
      PORTB |= (1<<PB2);
    data_mask[0]<<=1;
    //device++;
    _delay_ms(200);
void clr(void)
  uint8_t i,k;
  for (i=1;i<10;i++)
    PORTB &= ~(1<<PB2);
    SPI_TX(i);
    SPI_TX(0x00);
    PORTB |= (1<<PB2);
You should ask the moderator to move your post to the LEDs and Multiplexing forum.
Instead of making us watch a video.
  1. Tell us which type of 8x8 LED matrix did you buy.
  2. Tell us the schematic you used.
  3. Tell us the Arduino library you are using.
ieee488: You should ask the moderator to move your post to the LEDs and Multiplexing forum.
Where is that forum? I could not find it.
  1. It's the one connected with MAX7219 chip. I have both of these: [https://www.aliexpress.com/item/MAX7219-Dot-Matrix-Module-LED-Display-Module-For-Arduino-MCU-Control-Driver-3-2-3-2/32788194408.html?spm=2114.search0204.3.267.DMHq4e&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10613_10307_10615_10614_10142,searchweb201603_6,ppcSwitch_2_ppcChannel&algo_expid=d0c04e05-af90-4406-89ff-b1fb88a3f8a9-40&algo_pvid=d0c04e05-af90-4406-89ff-b1fb88a3f8a9&priceBeautifyAB=0]MAX7219 dot matrix 8x8]LED dot matrix 1 module](https://www.aliexpress.com/item/MAX7219-Dot-Matrix-Module-LED-Display-Module-For-Arduino-MCU-Control-Driver-3-2-3-2/32788194408.html?spm=2114.search0204.3.267.DMHq4e&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10613_10307_10615_10614_10142,searchweb201603_6,ppcSwitch_2_ppcChannel&algo_expid=d0c04e05-af90-4406-89ff-b1fb88a3f8a9-40&algo_pvid=d0c04e05-af90-4406-89ff-b1fb88a3f8a9&priceBeautifyAB=0)
dot matrix 4 modules
  1. It's simple direct connection to my Arduino Nano board. Here's another video: dot matrix 4 modules
  2. It's my own AVR C code.
Problem solved.
I have to initialize it properly.
void SPI_TX(uint16_t data)
  SPDR = data>>8;
  SPDR = data;
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0A00); // intensity
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0900); // decode mode
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0B07); // scan limit
  PORTB |= (1<<PB2);
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0F00);
  PORTB |= (1<<PB2);
  for (i=0;i<4;i++)
  PORTB &= ~(1<<PB2);
  SPI_TX(0x0C01); // shutdown on
  PORTB |= (1<<PB2);
