(Solved)Steppermotor and serial.print and read combined
Robin,
I changed the code to see how a real stepper would react instead of pulsing led 13 in the void stepperMotor()
So for the test I want to move the stepper in 180 degrees = 100 steps just to see if it works and if there is any motion.
But the stepper only steps one step per second with this code.
Paco
[/// this is just to test the understanding of using the HX711 and steppermotor
#include <HX711.h>
#include <AccelStepper.h>
// HX711.DOUT	- pin #A1
// HX711.PD_SCK	- pin #A0
HX711 scale(A1, A0); // 24 bit load cell amplifier
AccelStepper stepper(1,9,8); // set up the stepper as 4 wire bipolair on pin 8,9 for EASY DRIVER or other driver board
unsigned long startMillis;
unsigned long endMillis;
unsigned long currMillis;
unsigned long prevMillis;
unsigned long intervalMillis = 10; // do not change
byte maxTests = 100;
byte curTest = 1;
byte maxSteps = 100;
byte curStep = 1;
long scaleData = 0;
  stepper.setMaxSpeed(3000);
  stepper.setSpeed(3000);
  stepper.setAcceleration(800); // do not remove!
  prevMillis = millis();
  if (curTest > maxTests)
    return;
  startMillis = millis();
  curStep = 0;
  testTiming();
  endMillis = millis();
  curTest ++;
  stepper.run(); // does it block the 100 steps?
void testTiming()
  while (curStep < maxSteps)   // will loop through the steps at the speed set by intervalMillis
    currMillis = millis();
    if (currMillis - prevMillis >= intervalMillis)
      stepMotor();
      prevMillis += intervalMillis;
      curStep ++;
  // now the Scale should be ready for reading
  scaleData = (scale.read()/100);
  Serial.print("B,");
  Serial.println(scaleData);
  Serial.print("A,");
  Serial.println(stepper.currentPosition());
void stepMotor()
  stepper.moveTo(100);
code]
