[solved] STM32 BluePill IO issue with package from STMicroelectronics
Hi All,
I try to port code written for package STM32Duino.com (Roger Clark) working on the standard package from STMicroelectronics. It didn’t work.
So I tried to find out which port pins cause the problem.
It looks like no pin of port A or port B works. PC13 LED_BUILTIN works.
What do I need to do to get pinMode() and digitalWrite() work on port A and port B on BluePill?
Jean-Marc
//BluePill_IO
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
#if defined(ARDUINO_ARCH_STM32F1)
  // see https://github.com/rogerclarkmelbourne/Arduino_STM32/issues/222
  Serial.end(); // needed for PA11, PA12 to work
  uint32_t mapr = AFIO_BASE->MAPR;
  mapr &= ~AFIO_MAPR_SWJ_CFG;
  mapr |= AFIO_MAPR_SWJ_CFG_NO_JTAG_SW;
  AFIO_BASE->MAPR = mapr; // remap JTAG pins as GPIO
#elif defined(ARDUINO_ARCH_STM32) && defined(STM32F1xx)
  //RCC->APB2ENR |= 0x0000000C; // enable port A & B clocks, doesn't help
  uint32_t t = RCC->AHBENR; // delay
  uint32_t mapr = AFIO->MAPR;
  mapr |= AFIO_MAPR_SWJ_CFG_NOJNTRST;
  AFIO->MAPR = mapr; // remap JTAG pins as GPIO
#endif
  for (uint8_t i = PA0; i <= PA15; i++)
    digitalWrite(i, HIGH);
    pinMode(i, OUTPUT);
  for (uint8_t i = PB0; i <= PB15; i++)
    pinMode(i, i == PB2 ? INPUT : OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
    digitalWrite(i, LOW);
port pin names are not ordered in this package. fixed test:
//BluePill_IO
static const uint8_t pa[] = {PA0, PA1, PA2, PA3, PA4, PA5, PA6, PA7, PA8, PA9, PA10, PA11, PA12, PA13, PA14, PA15};
static const uint8_t pb[] = {PB0, PB1, PB2, PB3, PB4, PB5, PB6, PB7, PB8, PB9, PB10, PB11, PB12, PB13, PB14, PB15};
#endif
  for (uint8_t i = 0; i <= 15; i++)
    digitalWrite(pa[i], HIGH);
    pinMode(pa[i], OUTPUT);
    digitalWrite(pb[i], HIGH);
    pinMode(pb[i], OUTPUT);
    digitalWrite(pa[i], LOW);
    digitalWrite(pb[i], LOW);
Conclusion: pinMode() does it also in this package. Next step is try without using pinMode().
solved?
why do you set pin high before pinmode?
solved?
Yes, in so far as most pins work now, and I can continue test. And fix the remaining errors I made.
I am used to do it that way, to avoid glitches, e.g. if used with logic analyzer. The result is processor dependent.
Final version for this test:
//BluePill_IO
  AFIO_BASE->MAPR = mapr; // remap JTAG pin A15 as GPIO
  GPIOA_BASE->CRL = 0x33333333; // 00 11 output PP, 50MHz, pins 0..7
  GPIOA_BASE->CRH = 0x33333333; // 00 11 output PP, 50MHz, pins 8..15
  GPIOB_BASE->CRL = 0x33333333; // 00 11 output PP, 50MHz, pins 0..7, pin2 useless on BluePill
  GPIOB_BASE->CRH = 0x33333333; // 00 11 output PP, 50MHz, pins 8..15
  mapr |= AFIO_MAPR_SWJ_CFG_JTAGDISABLE;
  AFIO->MAPR = mapr; // remap JTAG pin A15 as GPIO
  GPIOA->CRL = 0x33333333; // 00 11 output PP, 50MHz, pins 0..7
  GPIOA->CRH = 0x33333333; // 00 11 output PP, 50MHz, pins 8..15
  GPIOB->CRL = 0x33333333; // 00 11 output PP, 50MHz, pins 0..7, pin2 useless on BluePill
  GPIOB->CRH = 0x33333333; // 00 11 output PP, 50MHz, pins 8..15
#endif
#if 0
    if (PA13 == pa[i]) continue; // keep SWDIO for STLink
    if (PA14 == pa[i]) continue; // keep SWCLK for STLink
    if (PB2 == pb[i]) continue; // useless, high series resistor from jumper to processor pin
#endif
