(SOLVED) Strange behavior of devices on a bus i2C
Hello,
I don't know if this is the best board to talk about the problem I meet.
I have the following devices on an I2C bus:
When I put the RTC board and launch the Nick Gammon scanner I see the RTC and the eeprom.
If I add the light sensor, I see the three.
But if I add the LCD, I see all devices but the eeprom which completely disappear.
Any idea ?
Should I post this question on the protocoles/devices board ?
Thanks in advance
nbenm
So, with Nicks scanner you can see three I2C addresses, but not four.
How about if you only hook up the LCD, and none of the others, can you see it?
jackwp:
I can see Three addresses in spite of four.
If I remove only the LCD, all is OK
With RTC, eeprom and LCD, I see only RTC and LCD.
If I leave the LCD alone, I see 0x27 which is correct.
It looks like when I add LCD eeprom only goes away
Sometimes, in very rare cases, I see the four.
Btw, I have inverted eeprom and rtc addresses. It should be 0x68 RTC and 0x50 EEPROM
Could it be the voltage on the wire? When 2 or 3 are connected, ok, but by 4 to much load?
Do you have a pullup resistor on both lines? About 2K?
jackwp:
Good one!
I was using a pc usb port as power. I use now an external source and all is ok.
I've tried many many resets, but all is ok.
Many thanks to both
