[SOLVED]Strange behaviour with regards to use of Char Arrays passing to function
Hello Ladies and Gentlemen,
I am trying to get my head around using char arrays. I come from a C# background and OOP. But I trying my best to understand it all.
I have a snippet of code, that I have placed in my main programs loop.
It calls a function to do a VERY rudimentary encryption:
This is how I call the function:
//test Encode
   char s[128];
   memset(s,'\0',sizeof(s));
   strncpy(s,"welcome to my world!",128);
   DEEncryptStr(s,ENCRYPT,sizeof(s)) ;
   Serial.print("Enc:");Serial.println(s);
  // egg(s);
  //decode it
   DEEncryptStr(s,DECRYPT,sizeof(s)) ;
   Serial.print("Dec:");Serial.println(s);
Now, when I run it like that, (with the egg(s) function commented out) it runs just fine and produces this Serial output:
Enc:ˆíöðóý÷º«ä°²ë¦¨çâá÷ºÞÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Dec:welcome to my world!
Enc:�èóõöøò¿®áµ·î£­âçäò¿Û
However, when I uncomment the egg function and pass the char pointer to the egg function, the decryption section of my sketch returns rubbish.
Here is my Encryption/Decryption function:
void DEEncryptStr(char* msg,byte dowhat,int lenBytes)
  //Get the last 5 second gap
  int ss=(now()/5)*5;
  //turn the seconds into a char array of yyymmddhhmmss
  char sstime[13];
  sprintf(sstime, "%d", ss);
  char key[]="ABCDEFG1eewd!HIJ";    //todo:get from eeprom
  //make an improved key by adding the latest seconds
  char improvkey[sizeof(key)+20];
  strcpy(improvkey,key);
  strcat(improvkey, sstime);
  char seed='\0';
  if(dowhat==ENCRYPT)
    //strcat(improvkey, ssr);   //add the random number to the improvkey
    //xor the string by the key
    for(int x=0; x<lenBytes-1; x++)
      improvkey[0]=seed;
      seed=msg[x];
      for(int xx=0; xx<sizeof(improvkey)-1; xx++)
        msg[x]=msg[x]^improvkey[xx];
    msg[lenBytes-1]='\0';
  //decrypting section
  if(dowhat==DECRYPT)
    seed='\0';
      improvkey[0]=seed;
      //seed=msg[x];
      //update the seed only AFTER the HRF version is avail.
      seed=msg[x];
and here is the egg function:
void egg(char* s)
  char t[129];
  memset(t,'\0',sizeof(t));
  strcpy(t,s);
  t[128]='\0';
  Serial.print("Egg:");
  Serial.println(t);
So, after all of that, my question is :
What am I doing wrong when I sent the s char to the egg function that changes it ? I assume I am messing with the memory allocation?? Why does the damn thing decrypt just fine when I do nothing with the char called s, but as soon as I pass it around it doesnt decrypt???
Any help would be fabulously appreciated!
Regds
Paul
Snippets of your code don’t help much, but maybe you are running out of SRAM?
SurferTim: Snippets of your code don't help much, but maybe you are running out of SRAM?
Thanks SurferTim,
I will take a look at that!
I happen to have a sketch open with the freeRam function in it. Here is what I use. Call it just before you call the egg function.
int freeRam() {
  extern int __heap_start,*__brkval;
  int v;
  return (int)&v - (__brkval == 0 ? (int)&__heap_start : (int) __brkval);
// then call it like this
Serial.print(F("SRAM free: "));
Serial.println(freeRam());
Hi Tim,
Thanks, it's solved! indeed I was declaring the char array in the loop and obviously running out of SRAM
I now declared S as a global and it works fine!
Now...how do I mark this answer as solved???
Many thanks!
Paul
You can go back to your first post and edit it. You should be able to change the subject line to add [SOLVED].
SurferTim: I happen to have a sketch open with the freeRam function in it. Here is what I use. Call it just before you call the egg function.
int freeRam() {
  int v;
// then call it like this Serial.print(F("SRAM free: ")); Serial.println(freeRam());
Awesome MANY MANY MANY thanks Tim!!!!!!!!
