When I upload any type of sketch first time after starting IDE to Arduino board (either Uno (clone) or Nano Every (original)) I get following error message:
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp: In function 'void* operator new(std::size_t, std::nothrow_t)':
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp:59:60: warning: unused parameter 'tag' [-Wunused-parameter]
void * operator new(std::size_t size, const std::nothrow_t tag) noexcept {
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp: In function 'void* operator new [](std::size_t, const std::nothrow_t&)':
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp:68:63: warning: unused parameter 'tag' [-Wunused-parameter]
void * operator new[](std::size_t size, const std::nothrow_t& tag) noexcept {
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp: In function 'void operator delete(void*, const std::nothrow_t&)':
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp:103:55: warning: unused parameter 'tag' [-Wunused-parameter]
void operator delete(void* ptr, const std::nothrow_t& tag) noexcept {
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp: In function 'void operator delete [](void*, const std::nothrow_t&)':
C:\Users\Sebastian_2\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp:106:57: warning: unused parameter 'tag' [-Wunused-parameter]
void operator delete[](void* ptr, const std::nothrow_t& tag) noexcept {
Der Sketch verwendet 4354 Bytes (13%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 482 Bytes (23%) des dynamischen Speichers, 1566 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
The error message
is pretty much independent from the sketch being uploaded
does not show up when the sketch is uploaded a second time (or third, fourth, ...)
So, doesn't look harmful but it shows up now for quite a while - while it was not showing up a long time before (and I have no idea what has changed). So it is annoying ...
Any idea on how to get rid of it? Or is it a known bug?
Regards
Sebastian
