[SOLVED] String comparison after serial read
I am trying to compare a string created from characters sent over serial to a word. If the word “no” matches, led 13 should turn on, and if the word “off” matches, led 13 should turn off.
All goess right untill the comparison is made, I checked by writing back results to serial.
I just can’t get it to work? Any ideas?
String inData;
String test;
int testLed = 13; // LED on pin 13
void loop(){
  inData="";
  if (Serial.available() > 0) {
    int h=Serial.available();
   h--;
    for (int i=0;i<h;i++){
      inData += (char)Serial.read();
   Serial.read();
  //print it out
  if (inData == "") {
    //There is no spoon!
    Serial.println(inData);
    processData();
  delay(50); // Without delay, no data is shown in serial monitor.
void processData(){
      String t = inData;
      Serial.println("processing");
      if (t == "on") {
      Serial.println("light go ON");
      digitalWrite(testLed, HIGH);}
      if (t == "off"){
      Serial.println("light be gone");
      digitalWrite(testLed, LOW);}
First all the stuff with “h” is not needed!.
Second you need to check that you have the whole line (in this case).
Third you are not being sent on/off you are also getting newline or depending on the monitors settings.
Mark
    int h=Serial.available();    // h probably == 1 at this point, unless the entire string was sent before you entered loop()
   h--;                // now it's 0, not that this variable is required
      inData += (char)Serial.read();  // so this never gets executed
   Serial.read();  // but even if it did why read again?
This is bazaar, you’re doing two serial.reads() based on a single available() and anyway all this will be complete long before the second char is received let alone any more of the string.
And how are you testing for the end of the transmission?
Rob
I'm quite new to this so I followed some tutorials and changed/added some stuff here and there to get it working the way it is now. I don't know how else to do it.
I have tried without h--; but then it displays the word and skips to a new line on my serial terminal.
The data i'm getting seems to be allright, it's just not comparable..
Here (first row):
  processData();
You see on serial monitor the right word ?
How you set the central combo in Serial monitor (no line ending) ?
I see the exact same word I sent from my phone to the arduino in the serial terminal on my computer.
I can see that processData() is being called since my serial terminal also sends the word processing and that's all that happens...
Try with .StartsWith:
if ( t.startsWith("off") )
Try also this to be sure that before and after the word you send no other chars:
  Serial.print("#"); Serial.print(inData); Serial.println("#");
  processData();
For reading from serial you should read this: http://hacking.majenko.co.uk/reading-serial-on-the-arduino
Thanks for saving my day! The #-check showed my output was correct so it was the comparison which was the problem.
if ( t.startsWith("off") ) worked like it should, my serial output showed up only the led didn't work but that was another problem..
(I forgot --> pinMode(testLed, OUTPUT); ...)
Seems to be working great now!
Simple code to look for "on" and "off" to operate the board LED.
\// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
Thx for that one, I'll have a look at it later this week since works gonna take up most of my time the next few days.. :frowning:
