Hello everyone,
I am puzzled by the following situation. I try to use my own Debuggerfunctions using the same style as in HardwareSerial.h, but somehow the compiler does not like my approach
Localdebugger.h
#ifndef H_DEBUGGER_LOCAL
#define H_DEBUGGER_LOCAL
#include <Arduino.h>
typedef struct Timer {
bool SET;
float DELAY;
int COUNT;
int pos;
Timer() {}
void setTimer(float delay, float looptime) {
COUNT = delay/looptime;
SET = true; pos = 0;
bool time() {
if(pos>=COUNT) {
flush();
return true;
pos++;
return false;
void flush() {
SET = false; pos=0;
class Debugger {
public:
const byte CONTINUE = 'c';
const byte ESCPAE = 'e';
Timer TIMER = Timer();
void setTimer(float delay, float looptime) const {
TIMER.setTimer(delay,looptime);
extern const Debugger Debug;
#endif
main.cpp
#include "Debugger_Local.h"
Debug.setTimer(100,10);
Serial.println("Loop");
delay(2500);
For some reason this is not allowed. I also do not get a detailed error message
Linking .pioenvs/uno/firmware.elf
/tmp/ccvmRNtp.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x9e): undefined reference to `Debug'
I also get a warning which might indicate the problem, but I dont understand it
src/Debugger_Local.h:44:32: warning: passing 'const Timer' as 'this' argument discards qualifiers [-fpermissive]
Thanks for the help.
EDIT: I had a similar problem already. Of course the compiler does not see Debug, because it is not yet defined for this const variable
Creating a constructor
Debugger() {}
and calling it at the end using
extern const Debugger Debug = Debugger();
solved it.
Sorry for the inconvenience.
