I'm practicing with millis() and got on something I can't undurstand.
I modified the Blink Without Delay to accomodate 3 LEDs.
If I put 3 different intervals
long interval5 = 1000; // interval at which to blink (milliseconds)
long interval6 = 2000;
long interval7 = 3000;
the LEDs start blinking in sync and after about 1 minute get out of sync.
but then,
If I put 3 times the same interval
long interval6 = 1000;
long interval7 = 1000;
the LEDs never get out of sync!
I first thought that since the code for each LED passes through the loop turning them on or off one after the other, the small difference in the order of appearance slowly accumulates and ends up busting the pattern, but then the same would happen with equal intervals.
what am I missing?
here's the code
// constants won't change. Used here to
// set pin numbers:
const int ledPin5 = 5; // the number of the LED pin
const int ledPin6 = 6;
const int ledPin7 = 7;
// Variables will change:
int ledState5 = LOW; // ledState used to set the LED
int ledState6 = LOW;
int ledState7 = LOW;
long previousMillis5 = 0; // will store last time LED was updated
long previousMillis6 = 0;
long previousMillis7 = 0;
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
// set the digital pin as output:
pinMode(ledPin5, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(ledPin7, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
unsigned long currentMillis5 = millis();
unsigned long currentMillis6 = millis();
unsigned long currentMillis7 = millis();
if(currentMillis5 - previousMillis5 > interval5) {
// save the last time you blinked the LED
previousMillis5 = currentMillis5;
if (ledState5 == LOW)
ledState5 = HIGH;
ledState5 = LOW;
digitalWrite(ledPin5, ledState5);
if(currentMillis6 - previousMillis6 > interval6) {
previousMillis6 = currentMillis6;
if (ledState6 == LOW)
ledState6 = HIGH;
ledState6 = LOW;
digitalWrite(ledPin6, ledState6);
if(currentMillis7 - previousMillis7 > interval7) {
previousMillis7 = currentMillis7;
if (ledState7 == LOW)
ledState7 = HIGH;
ledState7 = LOW;
digitalWrite(ledPin7, ledState7);
Is wrong, only have one value of currentMillis to compare all the LED times.
What happens is that you can get a change in the value between one and the next
AWOL;
ok I'll try to rewrite the program and put everything in little boxes (arrays). First I wanted to check if the program worked and I thought of doing this later on (to rewrite it in a nicer way), but then it desyncronized so fast I thought something must be wrong.
KE7GKP:
It is not clear whether this is just an abstract, generic, academic exercise or whether you are trying to ELIMINATE this gradual loss of sync, or maybe whether you are trying to PROGRAM some gradual randomness?
I am really trying to eliminate the loss of sync. But the reason I want this is purely holistic, I often need millis() and am in a learning process about them, this program for me is an introduction. I don't need those synced LED's themselves, but I need the knowledge to get them syncronized since I always need syncronized things ; )
Got it I think.
Change the :-
if(currentMillis5 - previousMillis5 > interval5){
to
if(currentMillis5 - previousMillis5 >= interval5)
in all three instances and it will work.
I will leave it to you to decide why, it's quite a nice penny dropping moment.
Ask if you can't get it.
what I get is that it was necessary to wait for the iteration of the loop() that came right after the one that made the interval condition true, so if I was ''adding'', say, 1ms at every iteration, that means;
long interval5 = 1000; // adding 3ms every 3 seconds
long interval6 = 2000; // adding 1.5ms every 3 seconds
long interval7 = 3000; // adding 1ms every 3 seconds
hence the out-of-syncness.
this also means that with equal intervals of, say, 1000ms, all the blinks were also being offset by 1 ms, but alltogether, rendering the effect unperceptible.
Also, I don't know, but shouldn't the code for the example of the blink without delay be modified like this. It seems to me this is a better way of writing it.
Close.
What is happening is that you don't get the action until the millisecond after the time so
1000 times out in 1001 mS
2000 times out in 2001 mS
3000 times out in 3001 mS
As they are no longer multiples of each other they will not be in sync.
If you want to prove this then use the original program and set the times to:-
999
1999
2999
If they stay in sync that's it.
Note you need to see the millis() clock every milli second. If not then calculate the next time not from the current value of millis() but from the last threshold. That is add the time period to the threshold you previously calculated not the current clock. This keeps things in sync.
999
1999
2999
LED's in sync. So it's all aquestion of understanding where the treshold happens and how long (1millis) the program waits before giving the go to the next timer.
I'm not sure I understand what you mean here. Is it that it could happen that the millis() clock could sometimes be unavailabe(because of interrups I guess)? But I don't get how to go around the millis() clock, whatever you take as a reference point, you still use the same clock!? Hmm, I'm missing something again
If you wait until the millis() time is greater than the threshold then it happens the millisecond AFTER you want it to happen. By making it equals it happens at the exact time. Add the greater than as well in case something goes wrong and you over shoot it so use >= instead of ==. At the moment == will work just as well but it is not good practice to leave such a hostage to fortune.
Not quite what I am saying is supposing you add some extra code in your loop, and that code takes longer than 1mS to execute then you could get out of sync because when you do this:-
You are setting the LED to change at a time interval5 from now. BUT now is not in exact sync because of the extra time you took in the other code. So to get round this you do:-
previousMillis5 += interval5;
This keeps the time slices exact even if you are late in updating the next interval.
