(SOLVED) Tank Tracks Sketch
I think I just need another set of eyes here.
Simple sketch using for buttons to control two Tank Tracks.
I keep getting an error stating:
In function 'void loop()':
error: 'StateRightREV' was not declared in this scope
I think I have set it up right, My Arduino just disagrees with me. :wink:
Can someone spot where I borked this?
// Set Input pin numbers:
const int PinLeftFWD = 0;     // Left Track Forward
const int PinLeftREV = 1;     // Left Track Reverse
const int PinRightFWD = 2;     // Right Track Forward
const int PinRightRev = 3;     // Right Track Reverse
// Set Output pin numbers
const int PinDRVLeftFWD =  13;      // Output Left Track Forward
const int PinDRVLeftREV =  12;      // Output Left Track Reverse
const int PinDRVRightFWD =  11;      // Output Right Track Forward
const int PinDRVRightREV =  10;      // Output Right Track Reverse
// Set initial State
int StateLeftFWD = 0;         // variable for reading the pushbutton status
int StateLeftREV = 0;         // variable for reading the pushbutton status
int StateRightFWD = 0;         // variable for reading the pushbutton status
int StateRightRev = 0;         // variable for reading the pushbutton status
  // initialize the button pins as an input:
  pinMode(PinLeftFWD, INPUT);
  pinMode(PinLeftREV, INPUT);
  pinMode(PinRightFWD, INPUT);
  pinMode(PinRightRev, INPUT);
    // initialize the output pins:
  pinMode(PinDRVLeftFWD, OUTPUT);
  pinMode(PinDRVLeftREV, OUTPUT);
  pinMode(PinDRVRightFWD, OUTPUT);
  pinMode(PinDRVRightREV, OUTPUT);
void loop(){
  // read the state of the pushbutton value:
  StateLeftFWD = digitalRead(PinLeftFWD);
  StateLeftREV = digitalRead(PinLeftREV);
  StateRightFWD = digitalRead(PinRightFWD);
  StateRightRev = digitalRead(PinRightRev);
// Check if button is pressed
// if it is, the Drive State is HIGH:
  //** Left Track Forward **
  if (StateLeftFWD == HIGH) {
    // Move Left Track Forward:
    digitalWrite(PinDRVLeftFWD, HIGH);
  else {
    // Stop Left Track:
    digitalWrite(PinDRVLeftFWD, LOW);
  //** Left Track Reverse **
  if (StateLeftREV == HIGH) {
    // Move Left Track Reverse:
    digitalWrite(PinDRVLeftREV, HIGH);
  else {
    // Stop Left Track:
    digitalWrite(PinDRVLeftREV, LOW);
  //** Right Track Forward **
  if (StateRightFWD == HIGH) {
    // Move Right Track Forward:
    digitalWrite(PinDRVRightFWD, HIGH);
  else {
    // Stop Right Track
    digitalWrite(PinDRVRightFWD, LOW);
  //** Right Track Reverse **
  if (StateRightREV == HIGH) {
    digitalWrite(PinDRVRightREV, HIGH);
  else {
    // Stop right Track
    digitalWrite(PinDRVRightREV, LOW);
This line does not match the capitalization applied to the previous three lines, or what is expected later in the code.
Wha?
checks
Oh good lord...
Thank you... ::slight_smile:
Hahaha. Looks like that little 8-bit chip is smarter than you. :wink:
Before my second cup of coffe my baud rate is about 96 or so.
LOLz ;D
