Solved - TFT 480x320 display w/ shield works - but cannot upload sketch to Mega
This was posted in the stk500 subforum, but I think it belongs here. Problem has been solved.
To upload a sketch, I have to remove the display module from its shield, upload the sketch to the Mega, and re-insert the display module, and run the sketch.
Display: EastRising (BuyDisplay) 3.5" 480x320 TFT model TFTM035-6 (w/ RTP), ILI9488 controller, 16-bit interface
Only when the display is in place, the uploader complains: stk500 receivemessage() - timeout
I have read on this forum that this is a power issue, and the display sucks up too much power. The Mega and shield require 70 and 10mA respectively. The 3.3V display 100mA. I believe USB can deliver up to 500mA. In any case I supplied external power to the Mega, which made no difference. Then I wired to the shield's 5V and pumped 130mA into that. Again, no difference. The shield has a 3.3V voltage regulator for the display. It uses Arduino 3.3V for itself. In all cases the Mega and display were running normally.
Solution:
Finally got a message back from BuyDisplay. They told me to solder short the 10 jumper (probably related to D0 and D1), and solder open the Main jumper (which is 1mm x 2mm!). Now I can upload sketches. Nice way to sell your products where the shield must be resoldered, and without documentation.
This topic was automatically closed after 120 days. New replies are no longer allowed.
