İ have a 3.2" tft display and i want to use esp8266 (because i need wifi connection) but seems like my display need more than one analog pin, but there is only one analog in nodemcu, so how can i fix my problem?
There are many 3.2" displays and many boards with esp8266s on them. Can you please post pictures of what you are using?
Nodemcu: Buy NodeMCU LoLin ESP8266 Developement Board - USB Chip CH340 with cheap price
Thank you for replying
Where did you see that requirement ?
İ saw it in example codes
Please post a full example sketch and use code tags when you do rather than posting a picture of code. See How to get the best out of this forum
Analogue pins can be used as digital pins so there is very likely no requirement to explicitly use analogue pins
Your display uses 8bit parallel interface.
The ESP8266 doesn't have enough free pins to use with this display.
Ok thnx
Give me a second i will post it now
// the regular Adafruit "TouchScreen.h" library only works on AVRs
// different mcufriend shields have Touchscreen on different pins
// and rotation.
// Run the UTouch_calibr_kbv sketch for calibration of your shield
//Store: http://dx.com
// https://open-smart.aliexpress.com/store/1199788
// Board:OPEN-SMART UNO R3 5V / 3.3V, Arduino UNO R3, Arduino Mega2560
//3.2INCH TFT:
// https://www.aliexpress.com/store/product/3-2-TFT-LCD-Display-module-Touch-Screen-Shield-board-onboard-temperature-sensor-w-Touch-Pen/1199788_32755473754.html?spm=2114.12010615.0.0.bXDdc3
//OPEN-SMART UNO R3 5V / 3.3V:
// https://www.aliexpress.com/store/product/OPEN-SMART-5V-3-3V-Compatible-UNO-R3-CH340G-ATMEGA328P-Development-Board-with-USB-Cable-for/1199788_32758607490.html?spm=2114.12010615.0.0.ckMTaN
#include <Adafruit_GFX.h> // Core graphics library
//#include <Adafruit_TFTLCD.h> // Hardware-specific library
//Adafruit_TFTLCD tft(A3, A2, A1, A0, A4);
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft; // hard-wired for UNO shields anyway.
#include <TouchScreen.h>
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
// TFT Breakout -- Arduino UNO / Mega2560 / OPEN-SMART UNO Black
// GND -- GND
// 3V3 -- 3.3V
// CS -- A3
// RS -- A2
// WR -- A1
// RD -- A0
// RST -- RESET
// LED -- GND
// DB0 -- 8
// DB1 -- 9
// DB2 -- 10
// DB3 -- 11
// DB4 -- 4
// DB5 -- 13
// DB6 -- 6
// DB7 -- 7
// most mcufriend shields use these pins and Portrait mode:
uint8_t YP = A1; // must be an analog pin, use "An" notation!
uint8_t XM = A2; // must be an analog pin, use "An" notation!
uint8_t YM = 7; // can be a digital pin
uint8_t XP = 6; // can be a digital pin
uint8_t SwapXY = 0;
uint16_t TS_LEFT = 880;
uint16_t TS_RT = 170;
uint16_t TS_TOP = 950;
uint16_t TS_BOT = 180;
char *name = "Unknown controller";
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 260 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 260);
TSPoint tp;
#define MINPRESSURE 20
#define MAXPRESSURE 1000
#define SWAP(a, b) {uint16_t tmp = a; a = b; b = tmp;}
int16_t BOXSIZE;
int16_t PENRADIUS = 3;
uint16_t identifier, oldcolor, currentcolor;
uint8_t Orientation = 2; //PORTRAIT
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
void show_Serial(void)
Serial.print(F("Found "));
Serial.print(name);
Serial.println(F(" LCD driver"));
Serial.print(F("ID=0x"));
Serial.println(identifier, HEX);
Serial.println("Screen is " + String(tft.width()) + "x" + String(tft.height()));
Serial.println("Calibration is: ");
Serial.println("LEFT = " + String(TS_LEFT) + " RT = " + String(TS_RT));
Serial.println("TOP = " + String(TS_TOP) + " BOT = " + String(TS_BOT));
Serial.print("Wiring is: ");
Serial.println(SwapXY ? "SWAPXY" : "PORTRAIT");
Serial.println("YP=" + String(YP) + " XM=" + String(XM));
Serial.println("YM=" + String(YM) + " XP=" + String(XP));
void show_tft(void)
tft.setCursor(0, 0);
tft.setTextSize(2);
tft.print(F("Found "));
tft.print(name);
tft.println(F(" LCD"));
tft.setTextSize(1);
tft.print(F("ID=0x"));
tft.println(identifier, HEX);
tft.println("Screen is " + String(tft.width()) + "x" + String(tft.height()));
tft.println("Calibration is: ");
tft.println("LEFT = " + String(TS_LEFT) + " RT = " + String(TS_RT));
tft.println("TOP = " + String(TS_TOP) + " BOT = " + String(TS_BOT));
tft.print("\nWiring is: ");
if (SwapXY) {
tft.setTextColor(CYAN);
tft.setTextSize(2);
tft.println(SwapXY ? "SWAPXY" : "PORTRAIT");
tft.println("YP=" + String(YP) + " XM=" + String(XM));
tft.println("YM=" + String(YM) + " XP=" + String(XP));
tft.setTextSize(2);
tft.setTextColor(RED);
tft.setCursor((tft.width() - 48) / 2, (tft.height() * 2) / 4);
tft.print("EXIT");
tft.setTextColor(YELLOW, BLACK);
tft.setCursor(0, (tft.height() * 6) / 8);
tft.print("Touch screen for loc");
while (1) {
tp = ts.getPoint();
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
pinMode(XP, OUTPUT);
pinMode(YM, OUTPUT);
if (tp.z < MINPRESSURE || tp.z > MAXPRESSURE) continue;
if (tp.x > 450 && tp.x < 570 && tp.y > 450 && tp.y < 570) break;
tft.setCursor(0, (tft.height() * 3) / 4);
tft.print("tp.x=" + String(tp.x) + " tp.y=" + String(tp.y) + " ");
void setup(void)
uint16_t tmp;
tft.begin(9600);
tft.reset();
identifier = tft.readID();
switch (Orientation) { // adjust for different aspects
case 0: break; //no change, calibrated for PORTRAIT
case 1: tmp = TS_LEFT, TS_LEFT = TS_BOT, TS_BOT = TS_RT, TS_RT = TS_TOP, TS_TOP = tmp; break;
case 2: SWAP(TS_LEFT, TS_RT); SWAP(TS_TOP, TS_BOT); break;
case 3: tmp = TS_LEFT, TS_LEFT = TS_TOP, TS_TOP = TS_RT, TS_RT = TS_BOT, TS_BOT = tmp; break;
ts = TouchScreen(XP, YP, XM, YM, 260); //call the constructor AGAIN with new values.
tft.begin(identifier);
show_Serial();
tft.setRotation(Orientation);
tft.fillScreen(BLACK);
show_tft();
BOXSIZE = tft.width() / 6;
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
tft.fillRect(BOXSIZE * 2, 0, BOXSIZE, BOXSIZE, GREEN);
tft.fillRect(BOXSIZE * 3, 0, BOXSIZE, BOXSIZE, CYAN);
tft.fillRect(BOXSIZE * 4, 0, BOXSIZE, BOXSIZE, BLUE);
tft.fillRect(BOXSIZE * 5, 0, BOXSIZE, BOXSIZE, MAGENTA);
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
currentcolor = RED;
uint16_t xpos, ypos; //screen coordinates
tp = ts.getPoint(); //tp.x, tp.y are ADC values
// if sharing pins, you'll need to fix the directions of the touchscreen pins
// digitalWrite(XM, HIGH);
// digitalWrite(YP, HIGH);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
if (tp.z > MINPRESSURE && tp.z < MAXPRESSURE) {
// is controller wired for Landscape ? or are we oriented in Landscape?
if (SwapXY != (Orientation & 1)) SWAP(tp.x, tp.y);
// scale from 0->1023 to tft.width i.e. left = 0, rt = width
// most mcufriend have touch (with icons) that extends below the TFT
// screens without icons need to reserve a space for "erase"
// scale the ADC values from ts.getPoint() to screen values e.g. 0-239
xpos = map(tp.x, TS_LEFT, TS_RT, tft.width(), 0);
ypos = map(tp.y, TS_TOP, TS_BOT, tft.height(), 0);
// are we in top color box area ?
if (ypos < BOXSIZE) { //draw white border on selected color box
oldcolor = currentcolor;
if (xpos < BOXSIZE) {
currentcolor = RED;
} else if (xpos < BOXSIZE * 2) {
currentcolor = YELLOW;
tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE);
} else if (xpos < BOXSIZE * 3) {
currentcolor = GREEN;
tft.drawRect(BOXSIZE * 2, 0, BOXSIZE, BOXSIZE, WHITE);
} else if (xpos < BOXSIZE * 4) {
currentcolor = CYAN;
tft.drawRect(BOXSIZE * 3, 0, BOXSIZE, BOXSIZE, WHITE);
} else if (xpos < BOXSIZE * 5) {
currentcolor = BLUE;
tft.drawRect(BOXSIZE * 4, 0, BOXSIZE, BOXSIZE, WHITE);
} else if (xpos < BOXSIZE * 6) {
currentcolor = MAGENTA;
tft.drawRect(BOXSIZE * 5, 0, BOXSIZE, BOXSIZE, WHITE);
if (oldcolor != currentcolor) { //rub out the previous white border
if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
if (oldcolor == GREEN) tft.fillRect(BOXSIZE * 2, 0, BOXSIZE, BOXSIZE, GREEN);
if (oldcolor == CYAN) tft.fillRect(BOXSIZE * 3, 0, BOXSIZE, BOXSIZE, CYAN);
if (oldcolor == BLUE) tft.fillRect(BOXSIZE * 4, 0, BOXSIZE, BOXSIZE, BLUE);
if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE * 5, 0, BOXSIZE, BOXSIZE, MAGENTA);
// are we in drawing area ?
if (((ypos - PENRADIUS) > BOXSIZE) && ((ypos + PENRADIUS) < tft.height())) {
tft.fillCircle(xpos, ypos, PENRADIUS, currentcolor);
// are we in erase area ?
if (ypos > tft.height() - 10) {
// press the bottom of the screen to erase
tft.fillRect(0, BOXSIZE, tft.width(), tft.height() - BOXSIZE, BLACK);
Thanks for the links. It is very important to provide links. It means that we don't have to ask you for extra information and we don't need to guess.
Your TFT display is 8-bit parallel and needs 8 data lines + 4 control lines to operate.
The Touch panel needs at least two of these pins to be Analog.
The ESP8266 does not really have enough pins to run the TFT.
I suggest that you buy an SPI display like https://www.ebay.co.uk/itm/184884416177
This has TFT, Touch and SD that all operate via SPI.
Which means that you can use the ESP8266 single Analog pin for external measurement. And still have spare Digital pins for sensors etc.
Since you have already bought your Open-Smart board, it should work with Uno, Mega2560, Zero, Due, ...
You need an ESP32 for the WiFi. I don't support Open-Smart on ESP32.
David.
thnx for the reply david, can i ask some questions about your library? i wrote my code with that hacked library, and then i founded your library, so now i have to change anything in my code? to make it ok with your library?
This new version of the forum is fun or horror at the same time, dependent on your view!
You can see responders replying, and wait for the reply to be completed.
I always like to see the complete and founded responses from David Prentice.
Jean-Marc
I suggest that you delete any hacked library. Then install the genuine ones via the IDE Library Manager.
From C:\Users\ ...\Documents\Arduino\libraries\Mcufriend_kbv\extras\mcufriend_how_to.txt
19. OPEN-SMART Shields have different wiring to regular Uno Shields:
Edit utility/mcufriend_shield.h: #define USE_SPECIAL
Edit utility/mcufriend_special.h: #define USE_OPENSMART_SHIELD_PINOUT_xxx e.g. USE_OPENSMART_SHIELD_PINOUT_MEGA
Edit MCUFRIEND_kbv.cpp: #define SUPPORT_8352B
20. OPEN-SMART Shields can not read LM75A on a Mega because there are no SDA/SCL pins next on AREF header.
Uno: LM75A on pcb works. Difficult to add external I2C devices when Shield is plugged in.
Uno: All use of SPI bus should use SPI.beginTransaction(), SPI.endTransaction()
Leo: I do not support USE_OPENSMART_SHIELD_PINOUT_LEO
Mega: Old boards do not have SDA/SCL on AREF header. Only external I2C devices on COMMS header
Due: MAX809 Reset chip interferes with 3.3V RST on SPI header. Manual reset for Upload / Run.
Make these edits. Then run all of the library examples.
Most of them should work "out of the box".
I possess the same HX8352B Shield from your link.
If you have a problem with an example, quote Arduino board by name, example by name. Describe the problem in English (e.g. Google Translate from Turkish).
The library Touch examples are much more logical than your code in #12.
I suggest that you study the examples first.
David.
Thank you
