[Solved] The Examples do not work on my Genuino 101
Hi fellow community,
I use a genuino 101 on my windows 10 64 BIT Lenovo Notebook
I tried the web editor version, installed everything, the board is recognized by the online web editor.
I also succesfuly send a sketch and the editor itselfs claims everything is fine.
After sending the blink sketch, nothing happens. The Genuino 101 does not blink, no other example sketch does work.
However when I go to the Serial Port section, the board starts disconnect and reconnect on my windows notebook...
So a good start I think!
PS: I already switched the usb cable, problem still is there.
Some good information there but not quite enough.
What browser ?
That CREATE sees it is a good sign.
Can you turn on VERBOSE in the CREATE preferences and copy that over to here if you are having issues.
PLEASE USE CODE TAGS ( </> ) when pasting errors or logs or code.
I have yet to see my 101 blink either using the std blink sketch but this sketch works.
Or direct from CREATE
We have identified an issue on the 101, will keep you posted on the fix. Thanks for your patience!
We have pushed a new version of the plugin, that will be automatically updated into version 1.1.52. This should solve the 101 issue, let us know otherwise. Thanks!
