[SOLVED]The program enters the switch case but doesn't run the function ... !?
Greetings,
I have a weird problem about a bit of code.
//define pin numbers
const int directionPin = 2;// direction
const int stepPin = 5;// step
int detectorLeft = 9; // Left stop sensor
int detectorRight = 11; // right stop sensor
// define variables
const int ritardo = 50; // Minimum = 50
int inputCode = 2; // Default is 2 => the machine is stopped
boolean valD;
boolean valL;
// declare functions
void stepRight(int steps);
void stepLeft(int steps);
  Serial.begin (9600);
  pinMode(detectorRight, INPUT);
  pinMode(detectorLeft, INPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(directionPin, OUTPUT);
  delay(300);
  if (Serial.available() > 0) {
    // read the incoming integer
    inputCode = Serial.parseInt();
  switch (inputCode) {
    case 9  :
      Serial.println("Enter 9");
      stepLeft(1000);
      break; /* optional */
    case 10  :
      Serial.println("Enter 10");
      stepRight(1000);
    default :
/* One or multiple steps to the right */
void stepLeft(int steps) {
  int count = 0;
  while (count < steps) {
    valL = digitalRead(detectorRight);
    digitalWrite(directionPin, LOW);
    count++;
    if (valL == 1) {
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(ritardo);
      digitalWrite(stepPin, LOW);
  inputCode = 2;
/* One or multiple steps to the left */
void stepRight(int steps) {
  int count = 0;
    valD = digitalRead(detectorLeft);
    digitalWrite(directionPin, HIGH);
    count++;
    if (valL == 1) {
  inputCode = 2;
Here is what's happening. When I upload the code and then open the serial monitor, I send the input 10. The monitor prints the message but nothing happens (my stepper motor doesn't run). Then when I type 9 (or anything else), the respective function is called and only now if I type 10, the stepRight() function is called too. it is really weird. I've done a ton of tests and the observations are :
  • case switch above 9 don't work (I've tried with case 11) when they're first called after an upload.
  • One case switch between 1-9 has to be called before
  • The print message is always called (so the program enters the switch case) but the stepRight() is not called.
Thanks for your help
What have you got the Line ending set to in the Serial monitor ?
UKHeliBob:
"No line ending" and also, the baud in the monitor is set to 9600 (so no problem there either).
Can stop sensors prevent movement?
Do you have pull up/pull down resistors?
Otherwise an input pin will be open and read HIGH and LOW randomly, unless its closed.
If not use built-in pull up resistors. (remember that open switch is HIGH and closed is LOW)
  pinMode(detectorRight, INPUT_PULLUP);
  pinMode(detectorLeft, INPUT_PULLUP);
I found the problem. It was a silly one. In the stepRight() function, I was storing the detector value in valD but I was checking valL (unlike the stepLeft() function in which I was storing in valL and checking valL).
Sorry to bother you with this silly problem. I dont see a "solve" button, tell me if there is one to close this thread.
Yours
You can edit the title in the first post via the 'More' button. Usually folks add [SOLVED]
