Hello,
I'm starting with STM8, and the goal is to recognize the 8 buttons on the remote, the data is in this repository:
As I still couldn't implement the external interrupt, I tried to execute the routine of reading the bits inside the loop() but only one button performed well, for some reason the other buttons don't work well. It appears to be well synced with the times of one button, so data from the other buttons is being lost.
I noticed that there are few posts about using STM8 in the Arduino IDE.
I would like to find timer implementation references to count time in microseconds, and references to implement the external interrupt, does anyone know how to indicate a post?
Thank you.
This sample code does the counting in hexadecimal
Created by RTEK1000
Date: 2022-07-16
Repo.: https://github.com/rtek1000/RF_Magic_Controller_6803_IC/blob/main/Arduino/Test_keyboard.ino
Here's how to program:
https://circuitdigest.com/microcontroller-projects/programming-stm8s-microcontrollers-using-arduino-ide
(Tested using the STM8S103F3 model selected in the Arduino IDE)
BUG: Only the ON/OFF button worked well, the other buttons do not have the same performance.
#include"stm8s.h"
// ref.: https://www.stm32duino.com/viewtopic.php?t=719
// #define digitalPinToInterrupt(p) ((p)==(p)) // workaround-fix, empty macro is missing in header files
char c[5] = {36, 164, 164, 164, 0};
const char char_H = 17;
const char char_P = 25;
const char char_Off = 62;
// 17: H
// 18: seg e
// 19: seg b, c, d
// 20: seg g
// 21: seg d, e, f "L"
// 23: seg a, b, c, e, f "N"
// 25: P
// 28: seg a, e
// 29: seg a, b, d, e, f
// 30: seg d, g
// 31: seg c, d, e, g "o"
// 34: seg a, g
// 36: seg a
// 37: seg a, b
// 38: seg a, b, c
// 39: seg a, b, c, d
// 40: seg a, b, c, d, e
// 41: seg a, b, c, d, e, f
// 42: seg a, b, c, d, e, f, g
// 62: all off
// 64: 0
// 65: 1
// 66: 2
// 67: 3
// 68: 4
// 69: 5
// 70: 6
// 71: 7
// 72: 8
// 73: 9
// 74: A
// 75: b
// 76: C
// 77: d
// 78: E
// 79: F
// 93: seg a, b, d, e, f "C'"
#define Serial_TX 14 // PD5
Not Connected:
PD1 SWIM (ST-Link)
PB5 D3
PD4 D13
RF input:
PB4 D4
#define RF_in 4
Output:
PD3 D12
PD2 D11
Keyboard pinout
GND
PA3: D2
PA2: D1
PA1: D0
PC3: D5
PC4: D6
PC5: D7
PC6: D8
PC7: D9
#define key_0 2
#define key_1 1
#define key_2 0
#define key_3 5
#define key_4 6
#define key_5 7
#define key_6 8
#define key_7 9
bool key_0_old = true;
bool key_1_old = true;
bool key_2_old = true;
bool key_3_old = true;
bool key_4_old = true;
bool key_5_old = true;
bool key_6_old = true;
bool key_7_old = true;
long cnt1 = 0;
unsigned long millis1 = 0;
char val_0_F(int x);
void print_4_dig_dec(uint32_t x);
void print_4_dig_hex(uint32_t x);
void send_string(char *str);
void setup (void);
void loop (void);
char val_0_F_dig0(int x) {
return x + 64;
char val_0_F(int x) {
return x + 64; //0x80;
void print_4_dig_dec(uint32_t x) {
uint8_t x1000 = x / 1000;
x -= x1000 * 1000;
uint8_t x100 = x / 100;
x -= x100 * 100;
uint8_t x10 = x / 10;
x -= x10 * 10;
uint8_t x1 = x;
if (x1000 == 0) x1000 = 62;
c[0] = x1000;
c[1] = val_0_F(x100);
c[2] = val_0_F(x10);
c[3] = val_0_F(x1);
send_string(c);
void print_4_dig_hex(uint32_t x) {
uint8_t x1000 = x / 0x1000;
x -= x1000 * 0x1000;
uint8_t x100 = x / 0x100;
x -= x100 * 0x100;
uint8_t x10 = x / 0x10;
x -= x10 * 0x10;
uint8_t x1 = x;
c[0] = x1000;
c[3] = val_0_F(x1);
send_string(c);
Routine send_string source: https://github.com/tenbaht/sduino/blob/development/examples/uart-spl/uart_spl.c
void send_string(char *str) {
char c;
if (!str) return;
while ( c = *str++ ) { // assignment intented
while (!UART1_GetFlagStatus(UART1_FLAG_TXE));
UART1_SendData8(c);
volatile uint32_t flag = 0;
// void RF_interr(void){
void EXTI1_IRQHandler(void) {
flag++;
void setup (void) {
pinMode(Serial_TX, OUTPUT); // Serial TX
digitalWrite(Serial_TX, HIGH);
// digitalWrite(Serial_TX, LOW);
// digitalWrite(Serial_TX, HIGH);
// delay(42);
pinMode(RF_in, INPUT);
pinMode(key_0, INPUT_PULLUP);
pinMode(key_1, INPUT_PULLUP);
pinMode(key_2, INPUT_PULLUP);
pinMode(key_3, INPUT_PULLUP);
pinMode(key_4, INPUT_PULLUP);
pinMode(key_5, INPUT_PULLUP);
pinMode(key_6, INPUT_PULLUP);
pinMode(key_7, INPUT_PULLUP);
// // attachInterrupt(digitalPinToInterrupt(RF_in), RF_interr, CHANGE);
// ITC_DeInit();
// ITC_SetSoftwarePriority(ITC_IRQ_PORTB, ITC_PRIORITYLEVEL_0);
// EXTI_DeInit();
// EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOB, EXTI_SENSITIVITY_RISE_FALL);
// // EXTI_SetTLISensitivity(EXTI_TLISENSITIVITY_FALL_ONLY);
// enableInterrupts();
UART1_DeInit();
UART1_Init(9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO,
UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TXRX_ENABLE);
char init1[2] = {0xFF, 0};
send_string(init1);
delay(42);
send_string(init1);
send_string(init1);
delay(90);
while (1) {
send_string(c);
if (c[0] < 42) {
c[0]++;
c[1]++;
c[2]++;
c[3]++;
delay(100);
delay(600);
bool RF_in_new = false;
bool RF_in_old = false;
int cnt_bits_rf = 0;
unsigned long data_bits_rf = 0;
unsigned long data_bits_rf2 = 0;
unsigned int micros1 = 0;
unsigned int micros2 = 0;
const unsigned long data_addr = 0B0101010101010101;
const unsigned int data_on_off = 0B110000000;
const unsigned int data_pause = 0B001100000;
const unsigned int data_b_plus = 0B001111000;
const unsigned int data_b_minus = 0B110011000;
const unsigned int data_s_plus = 0B000011000;
const unsigned int data_s_minus = 0B111100000;
const unsigned int data_m_plus = 0B000000110;
const unsigned int data_m_minus = 0B111111000;
void loop (void) {
// Remote control patterns:
// 0000000000111111 111122222
// 0123456789012345 678901234
// ON/OFF: 0101010101010101 110000000
// PAUSE: 0101010101010101 001100000
// B+: 0101010101010101 001111000
// B-: 0101010101010101 110011000
// S+: 0101010101010101 000011000
// S-: 0101010101010101 111100000
// M+: 0101010101010101 000000110
// M-: 0101010101010101 111111000
// T: 1.570ms
// 0: 0.3985ms
// 1: 1.185ms
RF_in_new = digitalRead(RF_in);
if (RF_in_new != RF_in_old) {
RF_in_old = RF_in_new;
if (RF_in_new == true) {
// cnt1++;
micros1 = micros();
} else { // if (RF_in_new == false)
micros2 = micros() - micros1;
if (micros2 > 1050) { // 1185us + 100us // 398us - 100us
if (micros2 < 1350) {
data_bits_rf = (data_bits_rf << 1) + 1;
data_bits_rf = 0;
cnt_bits_rf = 0;
} else if (micros2 < 550) { // 1185us + 100us // 398us - 100us
if (micros2 > 250) {
data_bits_rf = data_bits_rf << 1;
data_bits_rf = 0;
cnt_bits_rf = 0;
// cnt1 = 0;
if (cnt_bits_rf != 25) {
cnt_bits_rf++;
data_bits_rf2 = data_bits_rf;
unsigned long data_addr_rf = data_bits_rf2 >> 9;
if (data_addr_rf == data_addr) {
//cnt1++;
unsigned int data_rf = data_bits_rf2 & 0x1FF;
// cnt1 += 0x1;
if (data_rf == data_on_off) { // Key Power
cnt1 += 0x1000;
} else if (data_rf == data_pause) { // Key Pause
cnt1 -= 0x1000;
} else if (data_rf == data_b_plus) { // Key B+ (Key Program +)
cnt1 += 0x100;
} else if (data_rf == data_b_minus) { // Key B- (Key Program -)
cnt1 -= 0x10;
} else if (data_rf == data_s_plus) { // Key S+ (Key Quick)
cnt1 += 0x10;
} else if (data_rf == data_s_minus) { // Key S- (Key Slow)
cnt1 -= 0x100;
} else if (data_rf == data_m_plus) { // Key M+ (Key Length +)
cnt1 += 0x1;
} else if (data_rf == data_m_minus) { // Key M- (Key Length -)
cnt1 -= 0x1;
if (cnt1 > 0xFFFF) {
cnt1 = 0;
if (cnt1 < 0) {
cnt1 = 0xFFFF;
// print_4_dig_hex(cnt1);
// millis1 = millis();
data_bits_rf = 0;
cnt_bits_rf = 0;
if (flag > 0) {
cnt1 += flag;
flag = 0;
if (millis() > (millis1 + 250)) {
millis1 = millis();
// if (cnt1 < 0x10000) {
// cnt1++;
// } else {
// cnt1 = 0;
if ((digitalRead(key_0) == LOW) && (key_0_old == true)) { // Key Length +
key_0_old = false;
cnt1 += 0x1;
} else if (digitalRead(key_0) == HIGH) {
key_0_old = true;
if ((digitalRead(key_1) == LOW) && (key_1_old == true)) { // Key Length -
key_1_old = false;
cnt1 -= 0x1;
} else if (digitalRead(key_1) == HIGH) {
key_1_old = true;
if ((digitalRead(key_2) == LOW) && (key_2_old == true)) { // Key Quick
key_2_old = false;
cnt1 += 0x10;
} else if (digitalRead(key_2) == HIGH) {
key_2_old = true;
if ((digitalRead(key_3) == LOW) && (key_3_old == true)) { // Key Program -
key_3_old = false;
cnt1 -= 0x10;
} else if (digitalRead(key_3) == HIGH) {
key_3_old = true;
if ((digitalRead(key_4) == LOW) && (key_4_old == true)) { // Key Program +
key_4_old = false;
cnt1 += 0x100;
} else if (digitalRead(key_4) == HIGH) {
key_4_old = true;
if ((digitalRead(key_5) == LOW) && (key_5_old == true)) { // Key Slow
key_5_old = false;
cnt1 -= 0x100;
} else if (digitalRead(key_5) == HIGH) {
key_5_old = true;
if ((digitalRead(key_6) == LOW) && (key_6_old == true)) { // Key Power
key_6_old = false;
cnt1 += 0x1000;
} else if (digitalRead(key_6) == HIGH) {
key_6_old = true;
if ((digitalRead(key_7) == LOW) && (key_7_old == true)) { // Key Pause
key_7_old = false;
cnt1 -= 0x1000;
} else if (digitalRead(key_7) == HIGH) {
key_7_old = true;
if (cnt1 >= 0x10000) {
cnt1 = 0;
