hello, i am new to arduino and i have a strange behaviour.
i can not explain myself.
i have a simple buildup.
a humidity sensor and 4 colored leds.
i made an alert flag and then the red led should blink.
that seems running all fine (blue was on for wet) until some minutes but then
i came back to the room i saw (only) the blue led was blinking!?
// Rot alarm
// Gelb dry
// Grün ok
// Blau wet
#include <dht_nonblocking.h>#define DHT_SENSOR_TYPE DHT_TYPE_11
//#define DHT_SENSOR_TYPE DHT_TYPE_21
//#define DHT_SENSOR_TYPE DHT_TYPE_22static const int DHT_SENSOR_PIN = 7;
DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );static const int BUTTON1_PIN = 2;
static const int LED_GREEN_PIN = 3;
static const int LED_RED_PIN = 8;
static const int LED_YELLOW_PIN = 9;
static const int LED_BLUE_PIN = 10;const long interval = 1000;
unsigned long previousMillis = 0;
bool alarm = false;
bool onoff = false;void setup( )
Serial.begin( 9600);pinMode(BUTTON1_PIN,INPUT_PULLUP);
pinMode(LED_GREEN_PIN,OUTPUT);
pinMode(LED_RED_PIN,OUTPUT);
pinMode(LED_YELLOW_PIN,OUTPUT);
pinMode(LED_BLUE_PIN,OUTPUT);}
void loop( )
float temperature;
float humidity;if(dht_sensor.measure(&temperature, &humidity)){
//--------------------------------- Serial Monitor
Serial.print( "T = " );
Serial.print( temperature, 1 );
Serial.print( " deg. C, H = " );
Serial.print( humidity, 1 );
Serial.println( "%" );
//--------------------------------- Plotter
//Serial.print( temperature, 1 );
//Serial.print( "\t" );
//Serial.println( humidity, 1 );}
if (humidity > 65){ digitalWrite(LED_BLUE_PIN,HIGH);} else {digitalWrite(LED_BLUE_PIN,LOW);}
if (humidity >= 35 and humidity <= 65){ digitalWrite(LED_GREEN_PIN,HIGH);} else {digitalWrite(LED_GREEN_PIN,LOW);}
if (humidity < 35){ digitalWrite(LED_YELLOW_PIN,HIGH);} else {digitalWrite(LED_YELLOW_PIN,LOW);}alarm=false;
if (humidity > 70){
alarm=true;
// test alarm=true;unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;onoff = not onoff;
}if(alarm == true and onoff==true){digitalWrite(LED_RED_PIN,HIGH);} else {digitalWrite(LED_RED_PIN,LOW);}
Image:
