[Solved] Top panel close button
Hello,
maybe you've already noticed or fixed it, the top X - close - button on second level menu sometimes is disabled and does not work. Please, in order to verify, try to switch between main menu links on the left and then click the X button.
Thanks
Hi @interpeo, you are right we didn't notice that! I'm going to fix it and the fix will be available in the next release, thank you
Perfect, thanks!
Hi! This issue has been solved, live now. Thanks again for your report
Hello,
perfect!
