Hello, everyone
I am developing a device transmits bme280 (temperature, humidity, pressure sensor)'s data to another arduino using rfm95 lora shield. I am using radiohead library and here is my transmitter code. This code transmits temperature data.
#include <SPI.h>
#include <RH_RF95.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
while (!Serial);
delay(100);
Serial.println("Arduino LoRa TX Test!");
// manual reset
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (!rf95.init()) {
Serial.println("LoRa radio init failed");
while (1);
Serial.println("LoRa radio init OK!");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
// Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
rf95.setTxPower(23, false);
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
int16_t packetnum = 0; // packet counter, we increment per xmission
float t = bme.readTemperature();
String data = String(t);
int dataLength = data.length(); dataLength++;
uint8_t total[dataLength];
Serial.println(data);
rf95.send(total, dataLength);
rf95.waitPacketSent();
and this code is for receiving
#include <SPI.h>
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
while (!Serial);
delay(100);
Serial.println("Arduino LoRa RX Test!");
// manual reset
delay(10);
delay(10);
while (1);
while (1);
if (rf95.available())
// Should be a message for us now
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.recv(buf, &len))
RH_RF95::printBuffer("Received: ", buf, len);
Serial.print("Got: ");
Serial.println((char*)buf);
Serial.print("RSSI: ");
Serial.println(rf95.lastRssi(), DEC);
Serial.println("Receive failed");
and in receiver serial monitor,
it just shows these kind of messages
15:40:43.488 -> Received:
15:40:43.488 -> 0 0 1 0 14 D4
15:40:43.521 -> Got:
15:40:43.521 -> RSSI: -25
there's no sensor data here.
Are there any errors in this code?
Thanks for your help
