Hi all,
I've got a problem when trying to deserialize a JSON received from Serial port. I've tried many ways but now I'm quite out of solution.
Here is the received JSON (I've raised my Serial buffer size to 256):
{"sensors": 2,"labels": ["garage","exterieur"],"values": [48.75608,2.302038],"heure":12,"minute":35,"seconde":50,"jour":12,"mois":2,"annee":2020}
This JSON is sent by another Arduino, I've checked the output and it is ok. For debugging purpose, I send it now with CoolTerm.
Here is how I currently (I've changed this part many times in order to find the problem) manage the Serial input:
void serialEvent(){
packet_size = 0;
if (Serial.available()){
memset(serial_packet_char,0,sizeof(serial_packet_char));
initialiseTFT();
tft.setTextSize(1);
tft.setTextColor(color_text);
tft.setCursor(5,20);
tft.print("Buffer : ");
tft.print(SERIAL_RX_BUFFER_SIZE);
tft.println(" bytes");
while(Serial.available()){
packet_size++;
serial_packet_char[packet_size-1] = (char)Serial.read();
serial_packet_char[packet_size] = (char)0;
tft.setCursor(5,30);
tft.print("Received : ");
tft.print(packet_size);
if (packet_size > 0){new_packet_received = true;}
The serial_packet_char is defined in the head of the program like this:
char serial_packet_char[SERIAL_RX_BUFFER_SIZE];
And same for the JSON document:
const size_t capacity = 2*JSON_ARRAY_SIZE(NB_SENSORS) + JSON_OBJECT_SIZE(9);
DynamicJsonDocument packet(capacity);
The new_packet_received variable is handled in the loop, and call the following function if true:
void handleNewPacket(){
Serial.println("Handling new packet, first cleaning");
packet.clear();
new_packet_received = false;
//DEBUG
Serial.print("-");
Serial.print(serial_packet_char);
Serial.println("-");
Serial.println("Now deserialize");
DeserializationError err = deserializeJson(packet, serial_packet_char);
Serial.println("End of deserialize");
The program run well until I send the JSON from CoolTerm. When I do that, I see properly the packet size on the TFT screen, but when the call to deserializeJson is done, the Arduino is rebooting.
Serial output when commenting the call to deserializeJson:
Start setup
PING
PING
PING
New packet ready to be handled
-{"sensors": 2,"labels": ["garage","exterieur"],"values": [48.75608,2.302038],"heure":12,"minute":35,"seconde":50,"jour":12,"mois":2,"annee":2020}-
PING
PING
Serial output when uncommenting the call to deseralizeJson:
Start setup
PING
PING
PING
-{"sensors": 2,"labels": ["garage","exterieur"],"values": [48.75608,2.302038],"heure":12,"minute":35,"®*WÉÑsetup
PING
PING
We can see that we have the print of the JSON string, but we don't have the "Now deserialize" message, we jump directly to the "start setup" string (which is in the setup block), and the message is truncated with ascii artefacts.
The "PING" are just 2 seconds ping done by my program to tell the other Arduino that this one still alive.
In addiction, I specify that after compilation of my program, the memory is quite full:
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
DATA: [========= ] 90.0% (used 1844 bytes from 2048 bytes)
PROGRAM: [======== ] 75.0% (used 24196 bytes from 32256 bytes)
Do you have any clue ? I've spent 2 days on that, and I am out of solutions...
