I have a board which is I believe a clone of the SparkFun Arduino Pro Micro, but it presents itself as an Arduino Leonardo. Both use a ATmega32U4.
I'm running the latest Arduino IDE 1.8.10 on a beta of macOS 10.15.0 Catalina. The latest version of the Arduino IDE is supposed to address compatibility problems with Catalina.
When I plug the board in via USB, a serial device appears for a few seconds, but then disappears. If I try to program it during this brief window, I get:
avrdude: ser_recv(): read error: Device not configured
avrdude: butterfly_recv(): programmer is not responding
avrdude: ser_drain(): read error: Device not configured
avrdude: ser_send(): write error: Device not configured
Found programmer: Id = ""; type =
Software Version = .; Hardware Version = .
the selected serial port avrdude: butterfly_recv(): programmer is not responding
does not exist or your board is not connected
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude: ser_close(): can't reset attributes for device: Device not configured
I've also tried using a Linux virtual machine but I think the USB to VM bridge gets confused, and also does not work.
Is there something else to try?
