[Solved] Trouble with a Vertically Sliding Door
Hi all,
Disclaimer: this is my first post for my first project. Please forgive any forum etiquette transgressions or noobish questions.
I'm trying to make a vertically sliding door using a stepper motor. While it will mostly use a photoresistor to operate, I would like to put a button on it to open/close it.
Ideally the process would be Push button -> servo unlocks door position -> stepper motor opens door -> servo locks door position and a second button push would be Push button -> servo unlocks door position -> stepper motor closes door -> servo locks door position.
So far I've gotten a button push to operate the servo to unlock the door position and the stepper motor opens the door, but then it turns back to close the door before the servo locks it again. This tells me that the wiring is fine but I need a better way to separate the "Open" and "Close" commands. I am unsure how to do so. Here is the snippet of the section that I believe is causing me trouble:
#include <Stepper.h>
#include <Servo.h>
Stepper motor(200,2,3,4,5);    //The stepper motor is connected via a TB6612
Servo servo;
const int doorOpenClose = 13;  //Button on pin 13
int buttonStatusDoor = 0;
int pos = 45;                  //Servo position
int doorStatus = 0;            //Door position (1 = open, 2 = closed)
int doorMoving = 0;            //I don't want a second button press to cause the stepper to reverse and lose step count, this is to stop that
  pinMode(doorOpenClose,INPUT);
  servo.attach(6);
  motor.setSpeed(60);
  buttonStatusDoor = digitalRead(doorOpenClose);
  if (buttonStatusDoor == LOW)                       //This works fine, the button press is registering
    if (doorStatus == 1 and doorMoving == 0)         //If the door is open and not moving
      doorMoving = 1;                                //Door is moving, button pushes now don't register
      servo.write(135);                              //Unlocks position
      delay(300);
      motor.step(-100);                              //Steps in closing direction (test number, don't worry)
      delay(100);
      servo.write(45);                               //Locks door position
      doorStatus = 0;                                //Door position is saved as closed
      doorMoving = 0;                                //We can push the button again and have it respond
    if (doorStatus == 0 and doorMoving == 0)         //If the door is closed and not moving
      delay(300);
      motor.step(100);                               //Steps to open door
      delay(100);
      servo.write(45);                               //Locks position
      doorStatus = 1;                                //Door position is saved as open
      doorMoving = 0;                                //Button pushes will register again
I'm not sure if the doorStatus value change is causing it to open then close or if my if statements need changed. Any help (with the specified problem or general coding issues you may see) would be greatly appreciated. Thanks!
That is exactly what the program logic says to do, so you will need to rethink the approach.
 ... open it again ...
I would wait for button release, and then another button push before initiating a new action.
Thanks for reading the instructions and posting properly!
  1. You are not doing state-change detection on buttonStatusDoor, you might want to
  2. Your two if's need to be an if-elseif so it doesn't trigger the second body immediately after the first.
And don't post snippets, post the entire sketch, problems are often not where you think.
Thanks guys, the else if works perfectly. I was thinking that the IF statements would look at the first and (conditions met) perform it, get to the second and the button would no longer be LOW, or look at the first and (conditions not met) move to the second, perform that and then the button would no longer be LOW when it looped around. I thought I had tried the else if and it hadn't worked, hence the OP. Guess I did it incorrectly the first time. Thanks again!
