char daya[6], ampere[6];
float mA = ACS.mA_AC(); //ACS712 Current
dtostrf(mA, 4, 2, ampere);
float Watt = (235L*mA)/1000.0; // Calculate V*i/1000.0
if(Watt < 0){
Watt = Watt*-1; //Preventing the watt value goes negative
dtostrf(Watt, 4, 2, daya);
//Uplink to Antares
if (millis() - previousMillis > interval) {
previousMillis = millis();
sprintf(myStr, "ACS Current(A)= %d. Power Usage (VA) = %s", ampere, daya);
Serial.println("Sending to Antares... ");
Serial.println(myStr);
lora.sendUplink(myStr, strlen(myStr), mA);
txpower = lora.getTxPower();
Serial.print(F("Tx Power: ")); Serial.print(txpower);Serial.print("dBm");
// Check Lora RX
lora.update();
Trying to print the "ampere" into "ACS Current(A)= %d" but i already have a float (Power Usage (VA) = %s). Thanks you in advance.
