[SOLVED] undefined reference to
Hi I am getting the following error when declaring a class with static members.
Error:
/tmp/ccAgnwnD.ltrans0.ltrans.o: In function `sd_set_distance':
/tmp/445697414/build/sketch/Bicycle_Computer.cpp:116: undefined reference to `BicycleComputer::my_spd_dst'
collect2: error: ld returned 1 exit status
exit status 1
The code is really long and wont fit in a snippet so I've attached a zip file with all the code, sorry for the inconvenience but there's no other way from my perspective.
Bicycle_computer_nextion.zip (20.8 KB)
ningaman151:
Make and post an MCVE
Static class member usually requires 2 steps. First you define them inside the class. Second, you declare them outside the class. Example:
class A
   static int num;
A::num = 0;
arduino_new:
Code is correct, terminology is wrong. Declare inside, define outside.
arduino_new:
class A
  static int num;
A::num = 0;
gfvalvo:
I am getting this error when defining my variables.
/tmp/365392539/build/sketch/Bicycle_Computer.cpp:18:42: error: expected initializer before '.' token
static BicycleComputer::SpdDst my_spd_dst.spd = 0;
/tmp/365392539/build/sketch/Bicycle_Computer.cpp:19:42: error: expected initializer before '.' token
static BicycleComputer::SpdDst my_spd_dst.dst = 0;
/tmp/365392539/build/sketch/Bicycle_Computer.cpp:20:45: error: expected initializer before '.' token
static BicycleComputer::SpdDst other_spd_dst.spd = 0;
/tmp/365392539/build/sketch/Bicycle_Computer.cpp:21:45: error: expected initializer before '.' token
static BicycleComputer::SpdDst other_spd_dst.dst = 0;
exit status 1
The variables 'my_spd_dst' and 'other_spd_dst' are declared in another file.
Here is the relevant code:
class BicycleComputer
   struct SpdDst
      double spd;
      double dst;
    static SpdDst my_spd_dst, other_spd_dst;
This is tested code. (Sorry for the inccorect information above)
A.h
#ifndef A_
#define A_
struct SpdDst
   double spd;
   double dst;
class A
   static SpdDst my_spd_dst;
#endif
A.cpp
SpdDst A::my_spd_dst {1.5, 2.5};
arduino_new:
A.h
#ifndef A_
#define A_
struct SpdDst
  double spd;
  double dst;
class A
#endif
A.cpp
Thank you, that solved my issue. I will now mark this as solved :).
