Hello
I have a new UNO board
I done a bunch of examples and playing around. I to setup my I2C chip (pic18f23k22-I/SO data sheet is here http://www.web4robot.com/files/SerialLCDCtrN.pdf ), to the Ardiuno using UNObit 4 as SDA and UNO bit 5 as SDL. I am pulling power from the UNO 5v and ground. My LCD is connected to the IC2 chip (pic18f23k22).
I am trying to do a simple HEllO WORLD, WIthout a lot of luck. This is a brand new 20x4 LCD screen that works perfect in parallel output from uno. I have tried at least 4 different lib's and none of them seem to be working. Also from what I read in the spec my default I2C address is 76 (0x4C).
Here is the code I am using and it compiles and down loads fine, however the screen is dark but I can see some squares. I had this same problem when setup as parallel mode on UNO and fixed it buy getting the Backlight display to come on. However no such luck with I2C. The Phillips compliant I2C chip I have is suppose to be able to software control the Backlight. And both the codes I use call for it to be turned on. I must be missing something simple.
Does anyone have any sample code for this chip?
//DFRobot.com
#include <Wire.h>
//int ADDR = 0x4C;
LiquidCrystal_I2C lcd(0x4c,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.print("Hello, world!");
I also tried this code also with no errors and like the other the backlight does not come on but I can see faint full black squares. This whole problem might just be backlight. then again it could just be something I am not addressing correctly.
//YWROBOT
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
//LiquidCrystal_I2C lcd(0x4C,20,4); //test
lcd.init();
lcd.backlight();
lcd.setCursor(3,0);
lcd.setCursor(2,1);
lcd.print("Ywrobot Arduino!");
lcd.setCursor(0,2);
lcd.print("Arduino LCM IIC 2004");
lcd.setCursor(2,3);
lcd.print("Power By Ec-yuan!");
Any help or pointers in the right direction would be great, I have spent alot time on this already
Thanks
Brian
