Hello,
A have a project, where I want to control a Brushless motors with a ESCs and a Arduino Nano.
My problem:
The motors sometimes accelerate briefly and jerkily. [Shown in the video]
Video:
https://streamable.com/1hc1i
In the video, I always use the same speed. Because of this, the problem is not related to changing the speed.
It is definitely a programming issue, because the have two scripts. The first script works without the problem, but the second script have the problem.
Script 1 (my motor test script, also works with 4 motors) [is working]:
#include <Servo.h>
#define MIN_PULSE_LENGTH 1180
#define MAX_PULSE_LENGTH 1508
Servo mot;
mot.attach(7, MIN_PULSE_LENGTH, MAX_PULSE_LENGTH);
mot.writeMicroseconds(MIN_PULSE_LENGTH);
delay(8000);
for (int i = MIN_PULSE_LENGTH; i <= MAX_PULSE_LENGTH; i += 5) {
mot.writeMicroseconds(i);
delay(200);
for (int i = MAX_PULSE_LENGTH; i >= MIN_PULSE_LENGTH; i -= 5) {
delay(200);
void loop() {}
Script 2 (controlling the motor with remote control) [It does not work]:
If I add after setESC(realspeed); (in the middle of the code in the for loop) a delay(1000) the problem is rarer, BUT my command have a delay of 1 second (who would have thought that)
#include <SPI.h>
#include <Servo.h>
#include <RH_RF95.h>
#define RF95_FREQ 868.0
#define RFM95_CS 4
#define RFM95_RST 2
#define RFM95_INT 3
#define MIN_PULSE_LENGTH 1180 // Minimum pulse length in µs
#define MAX_PULSE_LENGTH 1508 // Maximum pulse length in µs
RH_RF95 rf95(RFM95_CS, RFM95_INT);
Servo m1, m2, m3, m4;
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
while (!Serial)delay(1);
delay(100);
Serial.println("Starting...");
Serial.println("Attach motors");
m1.attach(7, MIN_PULSE_LENGTH, MAX_PULSE_LENGTH);
m2.attach(8, MIN_PULSE_LENGTH, MAX_PULSE_LENGTH);
m3.attach(9, MIN_PULSE_LENGTH, MAX_PULSE_LENGTH);
m4.attach(10, MIN_PULSE_LENGTH, MAX_PULSE_LENGTH);
m1.writeMicroseconds(MIN_PULSE_LENGTH);
m2.writeMicroseconds(MIN_PULSE_LENGTH);
m3.writeMicroseconds(MIN_PULSE_LENGTH);
m4.writeMicroseconds(MIN_PULSE_LENGTH);
delay(8000);
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (!rf95.init()) {
Serial.println("LoRa radio init failed");
while (1);
Serial.println("LoRa radio init successful!");
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
rf95.setTxPower(23, false);
if (rf95.available())
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.recv(buf, &len))
char* received = (char*)buf;
if(received[0] == ':'){
String property = "";
String val = "";
bool pf = false;
for(unsigned int i = 1; i < strlen(received); i++){
if(received[i] == ',')pf = true;
else if(received[i] == ':'){
if(property == "speed"){
int realspeed = val.toInt()*5+MIN_PULSE_LENGTH;
setESC(realspeed);
pf = false;
val="";
property="";
else if(pf)val+= received[i];
else property+=received[i];
else if(strcmp(received, "rssi") == 0){
uint8_t data[] = "1";
rf95.send(data, sizeof(data));
rf95.waitPacketSent();
else Serial.println("Receive failed");
int lastValue = 0;
void setESC(int val){
if(val != lastValue){
m1.writeMicroseconds(val);
m2.writeMicroseconds(val);
m3.writeMicroseconds(val);
m4.writeMicroseconds(val);
lastValue = val;
Example input from remote control:
:speed,0:; //speed 0
:speed,65:; //max speed
Thanks for your answer.
