on my self made board with a 328P-AU (TQFP) there is an ISP interface and a socket to connect a FOCA USB to serial converter. The intention is first to burn the bootloader via ISP and then to use FOCA interface to upload sketches via the bootloader and test them with the Serial Monitor.
Burning a bootloader and also sketches via ISP works fine. But uploading sketches via the bootloader does not work.
Burning the bootloader with an USBasp is confirmed by "Done burning bootloader".
After that I connected the FOCA and tried to upload a sketch with following errors:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Klaus\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM16
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x38
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x38
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x38
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Then I tested the FOCA interface with a very simple sketch loaded via ISP:
while (!Serial);
void loop {
if (serial.available())
Serial.print(char(Serial.read()));
The FOCA interface works fine. Every time when I typed a character into the Serial Monitor it was echoed on the display. So serial input and serial output are ok.
A 100nF capacitor is connected between DTR pin of FOCA (pin 5) and the reset pin of the controller, see the attached image.
The schematic is the same as in several example schematics of Arduino boards.
This FOCA interface works with other Arduino boards.
What is wrong? What can I try further?
