I work on a small project running on battery 18650 it is in series and I seek to recharge via a USB port but my problem is that I am not very familiar with the charging of these batteries I think to use a buck boost converter and connect it to a mp2615 but I'm lost having never made a boost converter I'm littlr freak out of mistake and I'm not even sure it's a good idea
so in summary if someone could refer me to a possible method to accomplish this or reference components it would be awesome and if you have schema to realize that you are my god
yes I'll probably just fill in the basic schema the datasheet is pretty simple and test to see it must also look like there are plenty of things that I will not use as the HOST if you have to let it float or connect to the ground for the data pin or the termistor cut off pin i already handle that with my microcontroller x)
