Hi everyone,
I'm using an Arduino Nano Clone with a CH340G in an enclosure, which blocks the Mini USB Port.
I extended the USB Data lines (D+ and D-) lines and GND with ~10cm of twisted wire to a USB-Port in the front panel of the enclosure.
Simple Sketches like Serial Read upload and work fine, but when using the connected OLED Display (SSD1306, SPI) the CH340G stops responding to the USB Bus.
When using the original onboard USB-Port, everything works fine.
Is there something wrong with using the following pins for software SPI?
#define OLED_MOSI 13
#define OLED_CLK A0
#define OLED_DC 8
#define OLED_CS 7
#define OLED_RESET 12
Is 10cm of unshielded wire already too much for a stable USB?
lg, couka
