Hi all,
Is it possible to use the tone() function to generate a tone on pin 3 or 11?
I know if you are using the tone() function there will be interference with the PWM output of those timer2 pins.
If you can, why can you make a tone and can't you use PWM? Isn't tone using a PWM signal?
Thank you in advance.
Best regards,
Thomas
P.s. for a minimal example, see below:
const byte tonePin = 3;
void setup(){}
void loop(){
noTone(tonePin);
tone(tonePin, 1000, 500);
