[Solved]variable value not being updated - lcd.setCursor
Here is how it looks on the lcd; arrow doesn’t move at all.
“> Stop”;
here is how It should
“> Stop”
" > Stop"
" > Stop"
" > Stop"…etc
global value
int arps=0;
when timer is on; position shift to right for every sec
  nowtimer=millis();
  if(nowtimer-pretimer>=1000) {
    sec++;
    if(timer==1){
      lcd.clear();
      csec--;
      arps++;    //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      if(arps=11)arps=0;
    pretimer=nowtimer;
update and write the new location of the arrow
  case 1:
    if(timer==0){
    char y[17];
    sprintf(y, "Count Down %s", sp);
    lcd.setCursor (0,1);
    lcd.print (y);
    if(timer==1){
    lcd.setCursor (arps,1);     //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    lcd.write (ar);
    char y[17];
    sprintf(y, "%s", sp);
    lcd.setCursor (12,1);
    lcd.print (y);
    if(bb.clicks==1) timer=!timer;
One error is here:
if(arps=11)arps=0;
must be:
if(arps==11)arps=0;
luisilva: One error is here:
if(arps=11)arps=0;
must be:
if(arps==11)arps=0;
wow. I can't believe that I miss this error. thanks a lot. GOT IT
Sometimes it happens, and a new fresh pair of eyes can see easily that kind of things.
Off-topic: to get ride of that kind of bugs, you must write the if's like:
if (11 == arps) arps=0;
because if you miss one equal sign, you get a compiling error:
if (11 = arps) arps=0;   // This is an compiling error, and the compiler will tell you
