Solved "Void value not ignored as it ought to be"
Hello
I am just starting to write my own library to run an user interface with a LCD shield (HD44780 LCD + 5 key analog keyboard).
This library should have functions like menus that allows the user to select an option or to set a value etc...
The library has only one class called UI. I started yesterday and wrote only one function called "pause" This function takes three arguments: two char arrays (one for the top and bottom lines) and an int which is a delay. I did also wrote a demo sketch that should print something using that function then cler the screen after 3 seconds.
Here is the code:
Demo sketch:
#include"ui.h"//Include the UI library
#include<LiquidCrystal.h>
  LiquidCrystal lcd(8,9,4,5,6,7);//Create lcd instance
  UI ui(lcd);//Create a new instance of the UI object
  ui.pause("Haut", "Bas", 3);//Print something and wait for 3 seconds
  lcd.clear();//Clear the lcd
Header file
#ifndef DEF_UI
#define DEF_UI
#include <LiquidCrystal.h>
using namespace std;
class UI
  public :
  UI(LiquidCrystal lcd);//Constructor
  void pause(char up [], char down [], int pause);
  ~UI();//Destructor
  private:
  LiquidCrystal *m_lcd = 0;//Pointer to a LiquidCrystal object
#endif
Cpp file
#include "ui.h"
UI::UI(LiquidCrystal lcd)
  m_lcd = new LiquidCrystal(lcd);//The pointer is initialized with the address of the new LiquidCrystal object.
void UI::pause(char up [], char down [], int pause)
  *m_lcd->clear();//Clear the lcd
  *m_lcd->print(up);//Print the uppper line
  *m_lcd->setCursor(0, 1);//Set cursor to bottom line
  *m_lcd->print(down);//Print the bottom line
  delay(pause);//Wait xx milliseconds
UI::~UI()
  delete m_lcd;//Delete the LCD
I get the follwoing error:
void value not ignored as it ought to be
at this line
If I commment this line I get the error at
I know that this error occurs when you try to get a value from a void function. Example:
void function (argument)
  //some code
variable = function(argument);
I don't understand why I get this error. I don't see where would I not ignore the void value
Any help would be greatly appreciated. I'm sure there is a stupid mistake somewhere in the code...
Your UI constructor is gruesome crap and its comment wrong.
I would use something like
UI::UI(LiquidCrystal lcd) : m_lcd(lcd) {}
What do you think the '*' in the error lines should do?
Have you ever used pointers before?
