I got A1 connected to a battery, and have a LCD print out the voltage, but the voltage keep going up and down, down and up, from 4.2 - 3.4 -4.2 - 3.4, etc. why? this is totally not comprehensible by myself.
here is the part of coding for reading a voltage:
int batteryVolt = analogRead(A1);
battery = batteryVolt*(5.0/1024.0)*0.9;
nowVolt=battery;
here are all the code:
#include <Wire.h>
#include "ClickButton.h"
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address/ pins
ClickButton ba(9, LOW, CLICKBTN_PULLUP);
ClickButton bb(8, LOW, CLICKBTN_PULLUP);
int sec=0;
int Min=0;
int hr=0;
int Switch=1;
int pwm=0;
int Pwm=255;
float shunt=0;
int mah=0;
int ncc=0;
float battery=0;
int realMa=0;
float firstVolt=0.0;
float nowVolt=0.0;
unsigned long shuntTotal=0;
unsigned long nowtimer=0;
unsigned long pretimer=0;
unsigned long nptimer=0;
unsigned long pptimer=0;
lcd.begin(16,2); // initialize the lcd
ba.multiclickTime = 50;
bb.multiclickTime = 50;
pinMode(7, OUTPUT);
pinMode(A0, INPUT); //Shunt
pinMode(A1, INPUT); //battery
ba.Update();
bb.Update();
pwm=constrain(pwm, 0, 9);
Pwm=map(pwm, 0,9, 255,0);
nowtimer=millis();
if(nowtimer-pretimer>=1000) {
sec++;
shuntTotal+=realMa;
pretimer=nowtimer;
if(sec==60){
Min++;
sec=0;
if(Min==60){
hr++;
Min=0;
char buffer[8];
sprintf(buffer, "%01d:%02d:%02d", hr, Min, sec);
lcd.setCursor (0,0);
lcd.print (buffer);
lcd.setCursor (8,0);
lcd.print (firstVolt);
lcd.setCursor (11,0);
lcd.print (">");
lcd.setCursor (15,0);
lcd.print ("V");
nptimer=millis();
if(nptimer-pptimer>=300) {
char bufferx[17];
sprintf(bufferx, "%04dC %04dmA %01d", mah,realMa, pwm);
lcd.setCursor (2,1);
lcd.print (bufferx);
lcd.setCursor (12,0);
lcd.print (nowVolt);
pptimer=nptimer;
if(Switch==0){
lcd.setCursor (0,1);
lcd.print ("P:");
if(Switch==1){
lcd.print ("S:");
int shuntVolt= analogRead(A0);
shunt = shuntVolt*5.0/1024.0*1000.0*0.89;
mah=shuntTotal/3600;
nowVolt=battery;
if(shunt>50) {
realMa=shunt*pwm/9.0;
if(pwm==0){
realMa=0;
digitalWrite(7, LOW);
if (shunt<50)ncc++;
if(ncc>20){
realMa=0;
ncc=0;
if(realMa>50 && firstVolt==0.0) firstVolt=battery;
if(nowVolt < (firstVolt*0.7) && realMa<50) Switch=0;
if(realMa>50) digitalWrite(7, HIGH);
if(Switch==1) analogWrite(3, Pwm);
else {
analogWrite(3, 255);
realMa=0;
if(ba.clicks==1) pwm++;
if(bb.clicks==1) pwm--;
if(ba.clicks==-1) Switch=!Switch;
if(bb.clicks==-1) {
sec=0;
Min=0;
hr=0;
shuntTotal=0;
mah=0;
Switch=0;
