system
December 26, 2014, 10:52pm
1
What is the best way to get convert a HEX value back to ASCII to read a message from the Radio head library?
Also what is the best way to concatenate a number to the end of a char string? (I am testing some stuff and want to add a count number to a message)
If it's four bytes or less I believe strtol (strtoul ) will do it. You may have to prefix "0x".
Probably sprintf .
system
December 26, 2014, 11:03pm
3
Many thanks, it is a byte at a time... So no problem there.
Sorry for putting the question in the wrong place I thought I had put it in programming. I shall give myself a right telling off and no mistake!
system
December 26, 2014, 11:05pm
4
Ah that appears to convert an int to a string, (OK for half my issue) but I need to convert the hex for H to H.
KenF
December 26, 2014, 11:09pm
5
Do you have an example of the kind of format you're on about. Is it a string of hex values or hex values within strings?
system
December 26, 2014, 11:19pm
6
I am working with the radio head ASK library examples, specifically the following code to send a message:
char *msg = "hello";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
delay(200);
Serial.println("Message Sent!");
And the following to receive:
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.recv(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump it.
driver.printBuffer("Got:", buf, buflen);
//Serial.println("Got:", buf);
for (i = 0; i < buflen; i++)
Serial.print(buf[i]);
Serial.print(" ");
Serial.println("");
digitalWrite(13, false);
Which outputs
Got:
68 65 6C 6C 6F
104 101 108 108 111
What I would like is to convert the individual bits of hex back to something human readable.
Then I would like to add a number to the outbound message as well so I can track and see any losses.
KenF
December 26, 2014, 11:27pm
7
what happens if you change this lineSerial.print(buf[i]);
to Serial.print(buf[i], DEC);
system
December 26, 2014, 11:32pm
8
That is still printing the decimal equivalent of the HEX value that is in the buffer.
KenF
December 26, 2014, 11:52pm
9
So here's the thing. They're not "hex" values in the buffer, they're just values. It's just the way they get printed that makes them appear "hex"
You see Hex, Decimal, Binary are just different notations used to express values. The values in your buffer are just values. It's not until you chose to express those values that the notation you choose becomes relevant.
system
December 27, 2014, 12:02am
10
OK... So they went into the pipe as chars how do I view them as such?
KenF
December 27, 2014, 12:23am
11
char* chars=(char*) buf;
Serial.println(chars);
ChilliTronix:
I assume you are referring to strtoul . Null terminate string to an unsigned long. This...
(char) strtoul( "30", NULL, 16 )
...should return '0'.
system
December 27, 2014, 4:14pm
13
KenF:
That is interesting. It sort of works but I get extra payload:
The code:
digitalWrite(13, true);
int i;
Serial.print(" ");
Serial.println("!");
Serial.println("*");
Gives an output of:
Got:
68 65 6C 6C 6F
104 101 108 108 111 !
helloæÝvÞ}Ý"¿r³0ºêóar?aaîaîÒaîÒÒo Â
Got:
68 65 6C 6C 6F
helloæÝvÞ}Ý"¿r³0ºêóar?aaîÒaaîÒÒo Â
I wonder if it is anything to do with encoding with uint8_t?
The extra payload as you call it is because you do not have a null terminated array. So when recieving simply add a null ( zero ) to what you have recieved before you print it out.
A normal char array is closed with a '\0' at the end, if not you need a manual loop
Serial.print( (char)buf[i] );
system
December 28, 2014, 10:39am
16
@robtillaart , that was it! As simple as (char)!
