[SOLVED]Why do i get this error?
void motor1Move(unsigned long x){
   if (motor1.isDone())
   //Intervalo entre acionamentos
   delay(1);
   //Define o sentido de rotacao (CW = Horario)
   motor1.setDirection(CW);
   //Define o angulo de rotacao
   motor1.rotateDegrees(x);
  motor1.run();
unsigned long degrees_count(){
  unsigned long a = 0;
  while(a<18){
    a++;
    delay(330);
   return a;
void scan(){
  motor1Move(degrees_count);
void loop(){
I get the following error at this part of the code :
invalid conversion from ‘long unsigned int (*)()’ to ‘long unsigned int’
error: initializing argument 1 of ‘void motor1Move(long unsigned int)’
Hi Smug
Try changing this
to this:
motor1Move(degrees_count())
When you call a function which has no arguments, you still need to include ().
Regards
Ray
=D
Thanks so much, i was distracted and forgot that!
  while(a<18){
    a++;
    delay(330);
   return a;
Pretty stupid looking while loop, there. How many times will the loop iterate? Under what circumstances can the function every do anything but piss away a third of a second and then return 1?
