[SOLVED] Why this timer with millis() function fails?
I'm driving a transistor gate with a pin of an Arduino Pro Mini to turn off/on a led powered with +12V.
It works fine.
After, I introduced a configurable "timer" to turn off the led after a predefined number of seconds. In this way I avoid the led to dry the battery.
Furthermore, the max number of seconds that the led can stay ON depends on the value of a "timer" variable stored in a struct called "settings":
unsigned char LIGHT_TIMER;  // max is 255 seconds
The fragment of the code turning off the led is what follows:
// check timer for led light
if (LEDLIGHT_ON && ((millis() - LEDLIGHT_ONTIME) > config.settings.LIGHT_TIMER * 1000))
    digitalWrite(LEDLIGHT_POWER,LOW); // light off
    LEDLIGHT_ON = false;
Quite curiosly, I have obtained the following results:
config.settings.LIGHT_TIMER == 60 ----> FAIL. The led stays ON even after 60 seconds
config.settings.LIGHT_TIMER == 45 ----> FAIL. The led stays ON even after 45 seconds
config.settings.LIGHT_TIMER == 35 ----> FAIL. The led stays ON even after 35 seconds
config.settings.LIGHT_TIMER == 30 ----> SUCCESS. The led turns OFF after 30 seconds
config.settings.LIGHT_TIMER == 25 ----> SUCCESS. The led turns OFF after 25 seconds
where
LEDLIGHT_ON is declared as a bool,
LEDLIGHT_ONTIME is declared as an unsigned long (it is the time when the led is turned on).
I strongly suspect that the right-expression config.settings.LIGHT_TIMER * 1000 is automatically typed as an int, so values greater than 32767 cannot be represented.
Or what?
(deleted)
The full code is very long and complicated, involving many C++ objects. Posting it would be useless.
My question is restricted to the test condition of the if instruction above only. I would to know if this is the normal behaviour for the compiler.
gimpo:
Then post a short complete program that illustrates the problem.
The compiler has been very extensively tested. Whatever it does can be assumed to be normal behaviour. The chances that you have found a compiler bug are vanishingly small.
...R
gimpo:
Or what?
Yeah, that would be the problem. Define one of the operands to the multiplication as an unsigned long so that the math is done using unsigned long instead of int, eg:
config.settings.LIGHT_TIMER * 1000UL
Thanks for the replies.
@Robin2
I didn't mean that what above is a bug of the compiler, I have not enough experience about avr-gcc to state that.
I'm just blocked in debugging my program and the code above is the only place where I check for the "timer" status.
@DrAzzy
In this moment I'm writing a super-simplified version of the timer to illustrate the problem. I will try your solution and will post the results here in few (!) minutes.
Here we are again.
Below the super-simplified version that illustrate the problem:
unsigned long LEDLIGHT_ONTIME;
bool LEDLIGHT_ON;
int counter_seconds; // a simple counter to roughly represent the time running...
  // initialize serial communication at 9600 bits per second:
  LEDLIGHT_ON = true;
  LIGHT_TIMER = 30;
  Serial.println("LED light turned on...");
  counter_seconds = 0;
  LEDLIGHT_ONTIME = millis();
// the loop routine runs over and over again forever:
  if (LEDLIGHT_ON && ((millis() - LEDLIGHT_ONTIME) > LIGHT_TIMER * 1000))
      Serial.println("Turn off the LED, please!");
  counter_seconds++;
  Serial.println(counter_seconds);
The LIGHT_TIMER is set to 30 seconds and it works as expected :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
You are not paying attention.
LIGHT_TIMER * 1000
has maximum positive value of 32000.
BUT, if the variable LIGHT_TIMER is set even to just 35 then it loops forever printing seconds. No message is printed. :o
On the other hand, by substituting the instruction
with
if (LEDLIGHT_ON && ((millis() - LEDLIGHT_ONTIME) > LIGHT_TIMER * 1000UL))
then it works like a charm!
The message "Turn off the LED, please!" is printed after 35 seconds. :slight_smile:
Thanks DrAzzy, you're a genius!
jremington:
LIGHT_TIMER * 1000
Hi, you're not paying attention. I have supposed that in my first post (check it above), and I was looking for a confirmation about that by who know the compiler better than me... :-[
Anyway, that was the problem, as you pointed. I will mark this post as solved.
I think it will be useful to somebody else, since I've seen only examples/tutorials with few seconds as timer-value.
"unsigned char LIGHT_TIMER;"
Study number 'type'
https://learn.sparkfun.com/tutorials/data-types-in-arduino
BTW, you can add UL to a number tell the compiler to use 'unsigned long' in multiplication.
1000UL
Thanks karryd,
your suggestion was yet proposed (see some posts before), and it is the right one!
