Solved -- Why two lines cause error?
This simple code works fine
unsigned long Time1 = 0;
unsigned long Time2 = 0;
  pinMode(LED_BUILTIN, OUTPUT);
  if (millis() < 5000)
    digitalWrite(LED_BUILTIN, HIGH);
  else if (millis() < 10000)
    digitalWrite(LED_BUILTIN, LOW);
Why does adding lines A and B cause error ‘else’ without a previous ‘if’
    Time1 = millis();               //A
  Serial.println(Time1);           //B
if your "if/elseif/else" statements are more than one line of code you need to use curly brackets.
thats y u getting that error. C coding 101
Thank you!
sherzaad:
C coding 101
Easy for you to say! For some of us hobbyists who don't know diddly about programming these kinds of tidbits are secrets revealed :slight_smile:
sherzaad:
Correct, but ..
":advanced " C coding
These are NOT " curly brackets " , they are "blocks of code ".
232:
I thought they were called "braces" and they mark "statement blocks".
