[SOLVED] Wire communiction Arduino Rp2040 connect to Arduino mega (JSON)
Im trying to send data between my rp2040 connect using the "Wire" library. I managed to create a code that will send data efficiently, and it did work. My Code that works:
RP2040 code:
#include <Wire.h>
  Wire.begin();
  Wire.beginTransmission(8); // address of the Mega
  Wire.write("Hello from RP2040!"); // send the data
  Wire.endTransmission(); // end the transmission
Arduino Mega Code:
#include <Wire.h>
  Wire.begin(8); // address of the Mega
  Wire.onReceive(receiveEvent); // set the receive event
void receiveEvent(int numBytes) {
  while (Wire.available()) {
    char data = Wire.read(); // read the incoming data
    Serial.write(data); // print the data to the Serial Monitor
This code works great, but I want to send over JSON data. So I modified the code for it to get JSON data:
Rp2040 code:
#include <Wire.h>
#include <ArduinoJson.h>
// Define I2C slave address
const uint8_t SLAVE_ADDRESS = 8;
  Wire.begin();   // Start I2C communication as Master
  // Create JSON document
  StaticJsonDocument<200> doc;
  // Set sensor type and value
  doc["sensor"] = "Temperature";
  doc["value"] = 25.0;
  // Serialize JSON document
  String jsonString;
  serializeJson(doc, jsonString);
  // Send JSON data over I2C
  Wire.beginTransmission(SLAVE_ADDRESS);
  Wire.write(jsonString.c_str(), jsonString.length());
Arduino Mega code:
#include <Wire.h>
void receiveEvent(int numBytes);
    Serial.write(data);
    doc["json"] = String(doc["json"].as<String>() + String(data));
  // Deserialize the JSON document
  String jsonString = doc["json"].as<String>();
  DeserializationError error = deserializeJson(doc, jsonString);
  if (error) {
    Serial.print("Error: ");
    Serial.println(error.c_str());
    // Print the sensor type and value to the Serial Monitor
    String sensorType = doc["sensor"].as<String>();
    float sensorValue = doc["value"].as<float>();
    Serial.print("Sensor Type: ");
    Serial.print(sensorType);
    Serial.print(", Value: ");
    Serial.println(sensorValue);
But I have a problem The Arduino doesn't receive any information from the RP2040 code. I know the mega code works because I tried only to change this from:
To this:
  Wire.write("Hello, Mega!");
And the Arduino did get the data. So there is a problem when using this code: Wire.write(jsonString.c_str(), jsonString.length());
Any way I can send maybe JSON differently or have a better way or a way to fix my code?
Thanks
What does...
Serial.println(jsonString.c_str());
Serial.println(jsonString.length());
... produce?
This produce:
{"sensor":"Temperature","value":25}
35
What happens if you replace...
With...
Wire.write("{\"sensor\":\"Temperature\",\"value\":25}", 35);
Ok the info is now sent with that code Wire.write(jsonString.c_str(), jsonString.length()). but the code do get the info from the json doesnt work
Edit: The limit is 32 bytes so i need to see how i can send data with two lines or more with this type: {"sensor":"Temp","value":25} and also a way to decode it
Solved the data is being sent ok, make sure to not use over 32 bytes
